Question about RCA MM36100 36" TV
Rca tv mm36100
Won't turn on, when i plug it in it clicks once , no picture ,sound nothing.... rca mm36100
  • pm55 Feb 10, 2008
    I purchased this unit in 2003. I have had no problems with it until recently. It worked fine one day,the next day -nothing. That's right, nothing at all. It won't turn on by the button on the t.v. or the remote.
Power botton needs to be replaced just did that to mine and now works fine i would replace all bottons they are 2 dollars each
Posted on Jan 04, 2008
  • 934 Answers
There is a common problem in this unit with R14103 (33k 2watt ) resistor that opens. When open SMPS will not load so no other voltages beyond the 5v source to click the relay.
Another possibility is the Horz. drive transformer, RCA p/n# 243859 board location T14451.
Either of these possibilities are inexpensive fixes reletively speaking, so I would advise having it estimated by a qualified shop for repair..
Bill
Posted on Nov 25, 2007
SOURCE:
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Rca mm36100 power problem
Try a hard reset to this set first. To make it hard reset, unplug it from AC mains wall socket, and re-plug it back after 20 minutes or so. If this do not help you, the main system memory IC has to be replaced. This is not a costly part, but replacing it is a skilled work.
Aug 16, 2012 | RCA MM36100 36" TV
Good older rca tv favors blue green, red is weak. tint function doesent help this problem is there an adjustment inside?, where, turn down green blue or turn up red? jm
Hello; The red probably got low over a long period of time due to only one thing. The CRT/ Picture tube is getting weak and cost much more than the set sold for. The adjustments may only help a little and the set will get worse. These adjustments are done on your remote control with service menu accessed. You will need a Service Manual for instructions to do this, but I think it's time for another set. John
Apr 25, 2011 | RCA MM36100 36" TV
Hi im having a problem with my RCA tv. The problem is that when i turn it on I can hear the sound put there is no picture. Can anyone help me with this problem of mine.
Power supply regulator section inside your tv has some sort of trouble. It doesn't starts. We cannot predict the exact resaons for this kind of problem. There are so many reasons. It can be rectified only with the help of a technician. You just go for an experienced technician, or inform your nearest authorised service center for your tv.
Oct 16, 2010 | RCA MM36100 36" TV
Set will often have problems starting back up
you have a high voltage arching problem. the crt has about 33000. (thirty three thousand) volts on it. the anode lead is arching to the chassis(ground) around the crt(picture tube). the anode lead is the big red wire on the very top of back of crt. with the back off, you will see the big red wire and it will have a suction cup about 4 inches round connecting to picture tube. unplug. silicone around suction cup. let dry for 24 hours. enjoy. you might get a little shocked even when unplugged, but wont hurt you.
Nov 12, 2009 | RCA MM36100 36" TV
My rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
Jun 16, 2009 | RCA L32WD22 32 in. LCD HDTV
My rca television works fine exept for the sound
There is a switch on the back of the TV that toggles between the built in speakers or the external speakers. Try flipping it and see what happens.
Jul 21, 2008 | RCA MM36100 36" TV
No Sound
Hi Brickey,
These RCA televisions are notorious for this problem. You will need to have a technician change a chip called the EEPROM which holds the memory settings. The memory gets corrupted and the chip needs to be replaced or reprogrammed by unsoldering it, removing it, and inserting it into a device. After this is done it can be reinstalled and your sound will return.
MyTvGuy
Jan 23, 2008 | RCA MM36100 36" TV
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Aug 12, 2006 | RCA MM36100 36" TV
RCA MM36100 36" TV Logo
232 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
