Question about Maytag Dryers
Dryer will do nothing
Where arw fuses in dryer
  • 42 Answers
Depending on the drier. If you have a cover on the back with a bunch of 1/4 screws take those off and it will be white and skinny towards the bottom.
Or it could be in the bottom front on the vent tubes.
Posted on Aug 01, 2009
Dryer just stopped coming on. You hit the on button and nothing happens
You do not mention if you have checked the plug wiring , maybe it has a loose connection ?
Nov 24, 2014 | Kenmore Dryers
My indesit washer dryer makes a hell of a racket on the final spin. Tje bearings are fine but it looks like the shocks dont do anything. I can move the whole drum forwards and backwards about 2...
yes
it is called an air dampener and controls the drum movement to stop unbalance when starting
they come in a pack of 4 and average price is around $90.00aud
Dec 14, 2017 | Washing Machines
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Nothing comes on. Has power, door is closed, timer seems to be working but nothing happens.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Jan 09, 2011 | Estate TEDX640JQ Electric Dryer
Push the button nothing happens
check the wires again
you just might have a bad fuse
odd but it does happen
Oct 07, 2009 | Whirlpool LER4634J Electric Dryer
My TC 650 is not getting warm anymore. It works but nothing dries as there is no heat! Please help!
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
Sep 06, 2009 | Hoover Dryers
IT JUST SAYS THAT IT IS A HEAVY DUTY, IT IS PRETTY OLD. IT WILL NOT HEAT, IT SEEMED TO GET REAL HOT ON THE 1ST LOAD THEN NOTHING ON THE SECOND LOAD
Jul 16, 2009 | Kenmore 63942 Dryer
Dryer wont run
check the door switch and the main fuse on the blower box-mike
Mar 14, 2009 | Whirlpool LER4634J Electric Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
