Question about Drills
I am looking for the guide piece for a McGraw-Edison 1/2'' Drill Press. The model is a bench top model approximately 2 feet tall. The piece I'm looking for attaches the actual drill and then slides up the pole. Does anyone know where I can get this piece?
Hello, I have one with a bad winding. Maybe one of us can get a working unit. Contact me at girlscoutdad2004 at hotmail. Thanks, Bob
Posted on Jan 04, 2010
McGraw-Edison drill press 2620t2 power switch won't change to on. Is there a safety on the switch that will allow it to function?
if it is a round red button, twist it and pull out
because of safety reasons much of machinery now has this type of control switch so that in an emergency the button is pressed and the machine stops and it stays locked off
Nov 15, 2015 | Drills
How do I remove both pulleys from top of unidentified drill press?
15" Rockwell Drill Press pulley removal? - The Garage Journal Board
www.garagejournal.com > ... > The Tools > General Tool Discussion
May 3, 2012 - 7 posts - ‎2 authors I have 15" Rockwell Bench top drill press 15-017 I think circa 1971. ... You have toremove the machine screw and the pulley and bearing ... Drill Press Pulley Problem
Aug 31, 2013
Old COMPANION bench top drill press disassembly?
Mar 5, 2013
More results from www.garagejournal.com
Oct 23, 2015 | Drills
I'm looking for replacement bandsaw blades for a McGraw-Edison 10" Bandsaw, M/N - T6760. Any Ideas?
I have 11[6 tooth scrolling blades] & 3[3/8" 14 tooth general purpose metal cutting blades.T8380-16 & T8382-16 for McGraw Edison 10" bandsaw. blades are 57" been hanging in my garage for past 25 yrs lol. would like to sell to best offer. contact me at tazzdh1959@yahoo.com
Feb 24, 2011 | Saws
My McGraw Edison drill press is making a screaching noise,and it sounds like it is going lock up.
make sure one of your pulleys isnt rubbing on the guard housing other wise remove belt and run motor. if that sounds ok check and see if your spindle turns freely and has no play side to side if spindle shaft turns hard most likely a bearing problem could be sleeve or ball bearings will have to deassemble and inspect also if motor screams while running with belt off the motor will need new ball bearings .
Feb 20, 2011 | Drills
PRO- TECH DRILL PRESS BENCH MODEL
parts can be found on amazon, take a look here: Amazon com Drill Press parts. I hope this was helpful. Cheers
Jul 19, 2009 | Delta 15 331 15" 115/230V Variable Speed...
ProTech Drill Press
Sounds like you already have it figured out. Drill a round hole first then use a small square file to make the correct sized square. Depending on what the sheared piece looked like, you can find some square stock at the hardware store.
Oct 25, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Drill Presses Models
When shopping for a drill press, you'll have to choose between two basic models: 1. Bench-top drill presses mount directly to a workbench or on their own stands. Their compact size makes bench-top models good choices for small shops. 2. Floor-model drill presses usually have more powerful motors, more attachments/accessories and greater material handling capacities than bench-tops. The extra versatility makes floor models good choices for serious DIY and commercial shops.
Aug 27, 2008 | Dewalt Delta DP300L 12" Twinlaser...
Drills Logo
175 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
