Question about NetGear DGN2000-100NAS Router
ADSL issues The network connects and everything is plugged in as they should be, but the internet detects no ADSL service, is there any way I can fix this?
  • hoplex May 11, 2010
    how are you connecting it your ADSL? Check your filters?
  • 1,272 Answers
It seems that you will have to configuer the modem manually. Cöntact ur service provider and ask for the following info: adsl username adsl password VPI AND VCI, MULTIPLEXING METHOD. Once u have these info, follow the steps below on a wired computer connected to the router. 1. Open browser and type the address as http://192.168.0.1 or http://www.routerlogin.com. 2. Login with username as admin and password as password. 3. Click on Basic settings and enter the username and password. Click on ADSL settings and enter the required info. Rate it, if it helps.
Posted on Aug 01, 2009
My M1255nf works fine except that since we moved last month, when I get ready to send a fax the line is very noisey even with the phone line removed. I tried replacing the fax card but still same noise. I...
Do you have ADSL internet in your new place? If so you will need an ADSL filter plugged into the phone outlet and plugged into your fax machine. so it would look like phone wall jack--->filter-->fax machine.
ADSL internet creates it own jabber or digital noise in the line and the filter will stop your a analog device from hearing the noise. If you don't have a filter for your phone as well, you should get one. Without filters your ADSL internet will be slower as well. Your ADSL modem should have came with at least 4 filters, if not they can be purchased at your local Bestbuy, staples or computer place. NOTE: Filters only work if you have ADSL or DSL internet.
If you do not have ADSL or DSL internet and still have noise you may have to call your phone service provider to get them to diagnose your line issues. They can fix some noise issues from their end.
Chris
Sep 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
Can't Connect my Belkin router FSD7230-4 to the internet. I can connect to my new ADSL service when my computer is directly connected to the modem. When I'm going through the router it's not...
There are several reasons that this could be happening. Sometimes the DSL modem can be the cause. If it is configured incorrectly then it will not be setup to work in a routed bridge mode (what you need for it to work with the router). Easy fix for this: press the "reset" button in the back or bottom to set the modem to default settings then power cycle everything. Second, on your computer go to network and sharing center and find your adapter settings. right click on your Ethernet or wireless adapter (whichever you use to connect) and go to properties. Go to the TCP/IP protocal properties and check that everything is set to obtain its data automatically. Last thing to double check: Call your ISP and just verify the ip, login info, and DNS info are all correct. I have had an ISP give me the wrong DNS info before on accident and after several hours of troublshooting I called back and a different guy answered and told me that my DNS was wrong. I changed one number and POOF! Fixed! You can find more help for this at www.attivia.com or email us at support@attivia.com.
Sep 01, 2010 | Belkin Computers & Internet
Linux 5 is not detecting my broadband modem
The connecting to internet is very easy in linux .
There are many steps but i am saying simple one
Initially configure the adsl router with ppoe over ethernet and enable dhcp address option.
Next plug the ethernet cable from router to the inteface of lan card.
Boot the redhat machine.
In the system-->Administration-->network options check whether lan card is detected and active .
If the lan card is not active activate and save
In lan card select option assign assig ip automatically
check whether ip is assigned by using command ifconfig .
Mar 11, 2010 | Red Hat Enterprise Linux ES Basic Edition
I cannot get an internet signal while connected through my router
if the ADSL led is on (=adsl signal found ok) then
most likely you got the username / password wrong.
this is 90% the cause of a "no - internet connection"
the easyest way to solve it is to call your internet providers helpdesk as they can see in their computers the satus of your connection (and many other technical details) and will guide you to solve this.
now if the ADSL led is off (=adsl signal not detected on phone line) then check the cables / connections from your wall telephone socket to the adsl filter and to your router.
also check if you forgot to put a filter in every phone (or fax etc) you might have in your home. also check if you have a faulty telephone set somewhere in your house (better disconnect them to be sure). if all ok then, call your providers help-desk.
Sep 04, 2009 | Microsoft Broadband Networking MN-500...
Belkin Wireless G Plus MIMO router - connectivity problem
Connect one computer directly to the DSL modem using an Ethernet cable. If your DSL service includes a static IP address, then you will need to change the TCP/IP settings on your computer to connect directly to the DSL modem. that the router or other device on your network . For these you need to follow thse steps.
Belkin router blinking orange FIX belkin router amber light Issue
This may help you.
Aug 10, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Ubuntu doesn't see internet/router
Hvae you tried setting tie network manually in Ubuntu?
Network Manager is used in many sections of this guide - you can find it:
  1. In SystemAdministrationNetwork
  2. In the Notification Area. Its icon resembles two computer screens on top of each other, or a wireless signal indicator if you are connected to a wireless network.
Connecting using Wireless in Network Manager Network Manager (SystemAdministrationNetwork) supports Roaming mode. This allows you to connect to any available wireless network in range.
  1. In the Taskbar click the Network Manager icon.
  2. Select your wireless network from the list.
  3. Enter your Network Key.
  4. Click Connect.
Connecting to a hidden network
  1. Left click the Network Manager icon in the system tray.
  2. ClickConnect to Hidden Wireless Network
  3. In the network name text box enter the ESSID you are connecting to.
  4. Select the type of security used from the drop down list.
  5. Click Connect.
This section is about setting up an ADSL Internet connection using an ethernet PPPoE modem.
You will require a subscription with an Internet Service Provider, and an installed, functional Internet connection. Most modems have a light which will be lit if it is currently connected to the Internet. You will also need your username and password for the Internet account.
Setting up PPPoE To set up the modem:
  1. Open a terminal (ApplicationsAccessoriesTerminal)
  2. In the terminal, type
    sudo pppoeconf
  3. A text-based menu program will guide you through the following steps:
    1. Confirm that your Ethernet card is detected.
    2. Enter your username.
    3. Enter your password.
    4. If you already have a PPPoE Connection configured, you will be asked if it may be modified.
    5. Popular options: you are asked if you want the “noauth” and “defaultroute” options and to remove “nodetach”. Choose Yes.
    6. Use peer DNS - choose Yes.
    7. Limited MSS problem - choose Yes.
    8. When you are asked if you want to connect at start up, you will probably want to say yes.
    9. Finally you are asked if you want to establish the connection immediately.
  4. Once you have finished these steps, your connection should be working.
Starting the connection To start your ADSL connection on demand, in a terminal (ApplicationsAccessoriesTerminal) type:
sudo pon dsl-provider Stopping the connection To stop your ADSL connection, in a terminal (ApplicationsAccessoriesTerminal) type:
sudo poff dsl-provider Hope this helps.If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 02, 2009 | 2wire HomePortal 1800HG Router...
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
Network access problem
Contact to ur Internet Provider..Some network cable problem perhaps..
Dec 10, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Connecting to the internet
I was missing the NIC driver.
And got the answer off a free site :)
ciao
Sep 04, 2008 | D-Link SWT DSL-504T ADSL MODEM with 4...
LINKSYS WIRELESS - G WAG54GS
Diana, The router has lost its IP address from the ADSL gateway. Unplug the router from the wall for about a minute or two. Plug it back in..? If that doesn't work you need to login to your router and check the settings. or(there is a small reset button on the back of the router. Hold it in for 10 seconds the router will reset.) http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper http://www.linksys.com/servlet/Satellite?c=L_Content_C1&childpagename=US%2FLayout&cid=1114037290855&pagename=Linksys%2FCommon%2FVisitorWrapper If possible turn your computers off while resetting the connection. Some inter Microsoft networks will issue its own IP if it doesn't detect one. Good Luck, Tim
Feb 07, 2007 | Linksys Wireless-G WRTP54G Router
NetGear DGN2000-100NAS Router Logo
272 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
