-   i have a Maytag A412. I changed the belts. The motor is turning the pulley from motor to pump. The agitator is not turning. The new belt smells like it is going to burn off.-   Guest
Washer fills and agitates. Must manually set to rinse and spin. Spins at low rpm...whats the...
(More)
Washer fills and agitates. Must manually set to rinse and spin. Spins at low rpm...whats the cause/solution
The tub seems to be too easily mooving around in the housing. I opened the back expecting to see a...
(More)
The tub seems to be too easily mooving around in the housing. I opened the back expecting to see a broken spring inside somewere but could not see any. I can see the 3 horizontal short and stubby springs in place bu I can only see 1 longer vertical spring from the back. I can't feel any othee in front. Could it operate with a single vertical spring?
