Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
No power on electric durabuilt 1400 pressure washer
I have tried plugging it in several locations but will not run. It acts as if it has no power. I have tried resetting the power switch but nothing seems to work.
  • 47 Answers
Sounds like a pressure switch is sticking. usually causes this problem especially after being stood for a while not used.
have to remove cover to get to pressure switch, remove pressure switch piston clean regrease with silicon grease refit it m and all should be good.
Posted on Aug 01, 2009
  • Joe Mirabile
    Joe Mirabile Apr 10, 2017
    Andy, are you talking about the smooth brass stud that comes out of the pump and pushes a lever that closes the (electrical) microswitch? My motor won't run and if I manually close the (electrical) microswitch it still won't turn on. The microswitch is getting 120v so I am thinking it is the microswitch. I can't see the backside (the motor side) of the microswitch so I can't test it.
    New Friend:
Per Andy, mine (Karcher K 5.68) had the exact same issue.
Removed the cover, motor cover (to free the whole block from housing), and four large bolts (which holds the piston unit on), to free the pump unit and pressure switch.
Pressure switch had the chemical inlet at the top - removed this by removing the two pins holding it in place.
Removed valve from pressure switch - cleaned and regreased with silicon grease.
Used wire wool wrapped round some cloth over a screwdriver, and twisted round a few times in the pressure switch housing to clean the corrosion off. Regreased the housing, replaced the valve, tested.
Reassembled unit.
Viola, all good.
Posted on Mar 04, 2013
I had a similar problem on mine, noticed that the led on the GFCI plug was not lighting or resetting. I replaced the plug, and it took off fine. (Now I need to get another GFCI plug to put on.
Posted on Aug 05, 2009
Where can I purchase a pressure hose for a Durabuilt Model DB1303 washer - 1300 psi 1.6 gpm?
Well I don't know where you can get the exact hose but in my area there are company's who specialize in Hose's.
the place I buy mine is called EVCO . House of hose. Try looking them up .
They should be able to get you up and running in now time.
Feb 22, 2011 | Coleman Powermate DuraBuilt 1400 PSI...
My Durabuilt DB1303 pressure washer leaked oil. I
30 weight oil is what i use. Im assuming the oil plug does not have a little plastic dipstick. Place on level surface fill until just below thread line about 1/4" below the threads. I hope this has helped if i can help further let me know. Please rate how helpful this answer was. Good Luck and have a great weekend. Jeff
Apr 04, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
Where is the pressure switch located on a simoniz 1600 electric power washer?
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Aug 12, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Replacing Compasster, where on the terminal block does the black and white wires go?
Mar 08, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
609 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
