When you said this:
They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Here is the procedure to reset the parental lock code. It's important to note that this RESETS the parental lock. This is not a master password or anything to that extent.
Bring up
a screen where the unit asks you to enter in the parental code. You can
either insert a restricted disc, or enter the DVD setup menu and go to
"parental control" under custom setup.
When the screen asks for the code, press the SELECT button, then enter in the code "7444".
The
level adjustment under Parental Control dictates the strictness of the
player. The lower the value, the more strict it will be. Either
increase the value to lower the restriction, or disable the lock
entirely by setting it to "off".
Once you have made your
adjustments, be sure that the DVD tray is empty, and press the RESET
button on the front of the Playstation 2. It is imperative the tray is
clear of any DVD or game for the unit to save your settings.
the preset password is 3308. but first goto set up menu select rating press enter/play, select rating agin press enter/play, chose rating you want, then enter password 3308, press set-up to exit, press enter/play to start.
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Try this. The mintek dvd 2580 password " screen " looks like it wants four numbers, it actually wants five numbers. And they are 88888 as set by the manufacturer. Unless someone has changed it from its original password. If you ever need the code for the remote it should be 0717 . I hope this helps.
