Question about Lands Phones
The phone i have panasonic PQLV30023ZAB it reads no signal or move closer to base with a full charge reading.
  • 60 Answers
Try going thru the re-registration process of the set.
Dan
Posted on Aug 01, 2009
A key symbol on the left hand side of the phone is blinking. I'm unble to make a call,its telling me that no link to base. move closer to base, Try again. All the phone cords are in the socks and...
The key symbol is supposed to be an antenna.
It can't receive a signal.
There are a few possibilities:
- Too far from base. Move closer.
- Base is unplugged (no power at base station)
- Phone has become unregistered (unlikely).
If you need to re-register the phone, the process will vary depending in the model of the base station and will be covered in the manual.
Apr 05, 2011 | Panasonic KX-TGA101S Cordless Handset
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
Phone says no link to base phone stop working
Try unplugging the base unit and plugging it back in again. This is not guaranteed to help but has worked in the past.
Feb 28, 2010 | Panasonic Lands Phones
My cordless phone says No link to base Move closer to base - I have no dial tone - do i need a new battery?
This is the usual message that the phone gives when the battery has died and it has lost connection with the base unit. The usual fix is to remove and reinstall the battery, then place the unit on the charger for a full charge. This will usually fix the problem that you discribed. If after a full charge, you still get that message, you will most likely need a new battery. Good luck...
Nov 06, 2009 | Panasonic Lands Phones
No link to base
It sounds like you may be getting interferance from somewhere. Try moving the base unit to another location. Avoid putting by other electronics. T.V.s, microwaves, and such can mess with the signals. Hope this helps Good Luck!
Jul 24, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Both handsets tell me to move closer to base
Is the phone base near any microwave ovens, radios, televisions and other electronic products that could cause radio-frequency interference (RFI)? How far away from the base are you when it tells you to move closer to it?
Jan 07, 2008 | Panasonic KX-TG6502B Cordless Phone...
Panasonic phone
1st) you must identify the ranking order of your handset. Put all your handsets in the main base cradle and it will tell you which phone is your handset ie: (1) (2) (3) (4). (if you are reseting a handset, chose a number that is missing to reset your phone to) Now, with NO handsets in the main base cradle. Hold your phone and press "menu", then key in the numbers 00. Now, don't do anything with your handset just now. Go to the main base cradle. On the bottom, where it says"locator" press the select button until you get the desired phone rank needed. H1,H2,H3 etc... Now, press and hold "call". (The charging light should start flashing) Now, on your handset press the "OK" button on the top upper right corner. Your phone should now be working! If you are still having problems, call Panasonic Customer Service at 1-800-211-7262 for tech support.
Dec 23, 2007 | Panasonic KX-TG5633B Phone
Panasonic cordless phone with answering machine model number Kx-TG2632 2.4 gigga range I miss place the book and I need help to adjust the volumn thank-you
The message on crystal reads"no link to base. Move closer to base, try again". I put in a new battery in each phone and not sure if they are charging. i keep getting the same message. What is the problem and how do I solve it?
Thanks
Dec 02, 2007 | Panasonic KX-TG2632W Phone
Move closer to base
Either the phone is not registered to the base unit or the RF module is broken. It could be a bad battery but unlikely unless very old or you have not charged it. You should check the manual for registering the phone to the base unit.
Sep 07, 2007 | Panasonic KX-TG2584 Cordless Phone
Lands Phones Logo
118 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
