Question about Microsoft Xbox 360 Console
My units door is sticking and not opening but it powers up why want it open
    Problem Solver:
  • 10 Answers
DRIVE MOTOR IS BAD
Posted on Aug 04, 2009
My chamberlain garage door opener opens misterously. how do I change the code?
Anytime a door opens and/or closes randomly or doesn't work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone
Nov 17, 2010 | Chamberlain Powerdrive PD422D 1/2 HP...
Nissan Murano (05) Power Locks Sticking
The door lock actuator in that door is weak. Need to replace it.
Jan 31, 2010 | Nissan Murano Cars & Trucks
The dvd door will not open
Hello there:
On some of these units there is a very small hole that you can stick a paperclip into and press in and the door will now open if not unplug the unit and press the open button and hold it in while plugging it back in this should get the door open for you ok
best regards michael
Oct 26, 2009 | Emerson Televison & Video
I have several NUMARK CDN88 dual cd players with door opening issues. One player set the doors open and close too fast and dislodges the discs. On the other I have to power the unit up and down several...
Going through this problem myself. I've diagnosed that the drive (motor) unit should separate from a magnetic disc that sandwiches the CD between it and the motor. For some reason the mechanism isn't powerful enough to pull it away when the drawer wants to open, so it sticks. It seems to be a mechanical, rather than and electronic issue. I'm looking at replacing both drives rather than a fix, for reliability issues. I've got a number of CDN models and it's only the CDN88 that has this issue !
Apr 29, 2009 | Nu Mark Numark Cdn36 Dual CD Player CD...
Garage door opening by itself
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
Mar 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage opens/close when my neighbor engages his remote control
Do the above check just to be sure. If your unit is more thaan about 2 years old (freq. 390) you CAN buy an older non security plus remote and program it to your unit. this should eliminate the neighbors remote operating your door.
HOPE THIS HELPS
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door slider that connects to the pulley will not stick
IF YOU ARE REFERING TO THE TROLLEY THAT RUNS ON THE OPENER RAIL. IT MAY JUST NEED THE RELEASE RESET. PULL THE ROPE BACK TOWARD THE POWER UNIT AND IT SHOULD CLICK - SOME UNITS NEED TO BE PULLED STRAIGHT DOWN.
IF IT IS A SCREW DRIVE OPENER THE TROLLEY COULD BE STRIPPED.
IF YOU HAVE A SCREW DRIVE IT COULD BE THE DRIVE
Feb 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens after a power surge.
HOPE THIS HELPS
Dec 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Power door locks sticking
remove panel and to get at solenoid...electric door openers are simply a plunger thatpulls back ,same as your solenoid on the starter,these can get rusted or dry causing poor working order...spray with wd 40 and operate several times before closing
Oct 31, 2008 | 2005 Chrysler 300
Microsoft Xbox 360 Console Logo
186 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
