Question about KitchenAid Dishwashers
Dishes will not come clean,tried defferant soaps still the same
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Problem sounds like hard water. www.dishwasherfilter.com has an amazing product out that fixes this problem once and for all. it is a small filter that filters the hardminerals out of your water before entering the dishwasher. it is very affordable and guaranteed to work or your money back. you will be amazed how clean your dishes look.
Posted on Aug 11, 2009
  • 42 Answers
Could be that your machine has calcium build ups or doesn't drain well enough and leaves dirt from previous load.
Check if the arms that shoot out water are operating properly.
Posted on Aug 01, 2009
Soap is not dispensing, dishes are not clean
just throw the soap in the bottom as the soap trays get worn and stop working put soap in bottom and it will clean dishes 100%
May 03, 2016 | Dishwashers
Brand new bosch dishwater does not get dishes clean - food residu
Try the cascade new soap they have been changing the ingredents due to state requirments for the water treatment. also make sure spray arms and jet are free from food particles,also clean soap dispencer,If you want run CLR through dish washer no dishes to clean machine.Thanks
Jul 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishes not getting clean
Are dishes too greasy!
Check incoming water for free flow
Add correct quantity of soap as per manual. Use dish washer friendly soap. Fill rinse aid liquid in the dispenser meant for it.
Select a different cycle programe and give a try.
May 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
Dishes aren't clean, yet there's still soap residue in the cups
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
May 09, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Maytag dishwasher
Go buy a product called Lemi-shine and run it thru your dishwasher empty to clean out any hard water and soap deposits. If you can try using only about 2 table spoons of detergent and stay clear of the premeasured tablets. Most of the dishwashers being sold are low water usage units and it is very easy to overwhelm them with soap. It also helps if the oils from the foods are still on the dishes. People tend to clean the dishes to much before loading them and then the enzymes in the detergent have nothing to attach to. Basically this leaves the soap nothing to attach to except the dishes and hence you get cloudy dishes with soap stuck all over them.
Jan 30, 2010 | Dishwashers
Galaxy D/W Not Cleaning.Also leaving grit on dishes
You should try using a product called 'CLR' were normally you would put soap and also down the water supply pipe to the d/w. it will get rid of any calcium build up in the internal plumbing that could be caused by hard water. Don't have any dishes in when you do this 'clean run'. Next put a couple of dirty plates in and do another run with Cascade in the soap dish. That shoud fix it.
Carefull though CLR is corrosive, wear gloves and safety glasses. When you put the CLR down the water inlet pipe, if you can, turn the water back on before you start the clean run.
Dec 02, 2009 | Cars & Trucks
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwashers Logo
70 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
