Question about Minolta magicolor 2400W Laser Printer
Printing CD Labels
I am using Fellows NEATO US CD Labels (2up) USCD2lbl.NTT
I can't seem to get the printer to allign properly.
The adjustments provided within Roxio 8 Label Creator do not seem to work.
What am I doing wrong?
  • Minolta Master
  • 6,359 Answers
2 Suggested Answers
bandana_gyrl
  • 181 Answers
SOURCE: CD label (Neato) printing problem
Try to change your paper type to plain paper - it could be because it is a bit glossy that it thinks it's photo paper that is not inserted correctly.
Posted on Jan 16, 2009
How do I make a CD label?
There is a user manual on the install disc, pdf-format. To get to the manual, insert the install disc and wait for the small window to appear. At the bottom are some options, one being "View User's Guide". Click that. Or you could access the pdf-file itself manually and copy it to your hard drive: After inserting the install disc, go to "My Computer", right-click on your writer drive, choose "Explore", double-click on the folder named "SE1", and look for a file called "SE1 Guide.pdf". Open it, or copy it and paste somewhere on your computer for future reference. Read Chapter 4 of the user guide - it is titled "CD&DVD LabelMaker". Here follows the chapter, illustrations excluded:
Chapter 4
Introduction
CD&DVD LabelMaker makes designing and printing disc labels
and CD/DVD inserts fast, simple, and fun. Customize labels with
your own photos, text, video stills, and music playlists. Hundreds of
professionally-designed themes are included inside. Supports
label paper templates by Avery®, Memorex®, Neato®, CD
Stomper®, and Direct to CD/DVD Printing with supported printers.
Getting Started
When you first start the program, you're prompted to select the type of
project you want to design and print: Disc Label, Jewel Case Insert,
and DVD Case Insert.
Once you've selected the type of project, you'll be prompted to select
the paper to which you'll be printing. Select your template from the list,
and then click OK. (You can also change your project type by selecting
a new one from the top pull-down.)
Designing your label
You can customize various sections of your label/insert depending
on the selected paper type/template. The main workspace in the
Design Label tab starts by focusing on one section of the label/
insert. For example, if you're using paper that has two disc labels, the
focus will be zoomed onto one of those labels.
Adjusting your view
Notice the two up/down arrows on the left side of the screen. When
applicable, you can click either arrow to shift the focus to the top/
bottom of the page. Click the Paper View button in the lower left
corner to see a small thumbnail of the page. Click the section that
you'd like to edit, and it will appear in the main workspace.
Changing the Background
The right side of the screen lets you change the paper background,
either by applying a color (Use Color) or graphic design (Use
Theme).
To change the background color, select Use Color. A color palette will
appear. Click the color you want. The color will then appear on the
label/insert in the main workspace. The palette is fairly robust. If you
select a new color that doesn't appear on the grid, you can add it to
your My Favorite Colors.
To delete a custom color, select the color, then click the - icon.
To add a design, select Use Theme. A pull-down at the top lets you
select from a variety of categories. Each category offers a variety of
designs. To select a design to apply to your project, simply click it.
Click the button to the right of the pull-down to search for additional
designs online.
Printing your project
A print preview displays your project.
If there are certain sections/components that you'd prefer to exclude
when printing, simply click that object (it will appear dulled in color).
If you change your mind and decide to print the object, simply click the
object again and it will become active for printing.
Print with Mask: This option is only applicable when printing disc
labels. If you notice that your prints aren't aligning properly with your
labels, uncheck this box. Instead of printing over the circular area of the
label only, a square version of each photo will print to cover more area
and fill the disc label.
Select Your Printer: From the Printer pull-down, choose your
printer.
Modify Your Printer Settings: Click the Printer Setup button to
view/modify your printer settings.
Set the Number of Copies: Use the arrow buttons to increase/
decrease the number of copies you'd like to print, or key in the value in
the available box.
(To be continued - ran out of space) From: 11407336
Dec 01, 2010 | Individual SlideShow Expressions
L.S. How can I print label direct on cd/dvd. I have the HP Photosmart C5280. Thank uou in advance. H. Polak
You can't print directly to a CD or DVD. You need to print on a CD or DVD labels and you can find it on a computer store like Comp USA or Best Buy for example.
This an example can see it on http://www.neato.com/ under DVD Labels Good luck.
Nov 09, 2010 | HP Office Equipment & Supplies
Jan 04, 2009 | HP Photosmart C8180 All-in-One InkJet...
Printing CD labels , can not get it to line up stright.
I have the exact problem with my HP Deskjet D2360...Done all adjustments, doesn't print in the outline of the label...help
Nov 09, 2008 | HP PSC 1510 All-In-One InkJet Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer skipping labels
Your labels are narrow, and might not be aligned beneath the gap sensor.
Remove the cover and make sure the labels are loaded all the way to the left (toward the inside wall of the printer.) There's a "label Guide" that keeps the labels from wandering to the right. There are two thumbscrews beneath the label path. The thumbscrew toward the back of the printer lets you adust the "label guide", which keeps the labels from wandering away from the sensor (and the proper printhead position).
Move the lever clockwise to open the printhead and adjust the guide so it is slightly snug against the labels but so that you can pull the labels without much effort.
The thumbscrew towards the front of the printer allow you to position the gap sensor to detect the leading edge and trailing edge of the label, so the printer can . If your printer used to work OK, this might be in the proper place, but if it is loose, slide the thumbscrew left or right to center the sneosr between the edges of the label.
Jul 29, 2008 | Intermec EasyCoder 4440 Thermal Label...
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
CD Covers
What's Up Sparky? What is number of the cd paper you are using? Should be something like 'Neato Fellows VS-101-XXX-XX'? Or 'Avery 86XX'?
Jun 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Minolta magicolor 2400W Laser Printer Logo
301 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
