Question about Jenn-Air Refrigerators
8 year old regrigerator with bad compressor
I have a Jenn-Air Refrigerator that is only 8 years old. 27 cu. ft Designer Line Stainless Steel, and the Compressor is already going out on it. How can I afford to have it repaired withot purchasing a new refrigerator?
  • 42 Answers
Make sure it's not your start relay thats attached to the compressor.
Well if you are extremely handy you can purchase a new compressor and install it yourself.
Posted on Aug 01, 2009
This morning, my Frigidaire FFHS2322MS refrigerator had a pond of water in front, the compressor was clearly off and the lights inside were on. No error code of the displays, they were just bla
Have a technician test the start capacitor on the compressor. When they go bad the motor will draw excessive current which trips the thermal overload switch on the compressor. It usually resets itself once the compressor case has cooled down.
Nov 15, 2015 | Frigidaire FFHS2322MS 22.6 cu. ft. Side by...
Refrigerator s not cold
My guess is that the compressor is running all the time. See if the air is blowing through out the unit from the ductwork, if not the fan could be seizing up and running slowly. Though possibly unlikely the defrost may not be working causing an ice build up around the coils. If that's the case, you could have a bad defrost heater.
Sep 05, 2014 | U-Line C2275DWRS00 Stainless Steel (5 cu...
I have a samsung 1 year old fridge that wont get cold at all. the compressor, evap and condensor fans all run and i installed a schrader valve on low side to try to vacuum and charge with no luck. it
Compressor should rapidly bring pressure down from standing pressure to running pressure when switched on. If no change, compressor not pumping. Make sure the line tap valve isn't leaking, and the gas you used was correctly charged.
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
How to disconnect water line
If you following the water line into the back of your refrigerator, it will come to a threaded nut. That is how you disconnect it.
Jan 25, 2012 | Jenn-Air Jenn Air 19.8 Cu. ft. Counter...
My Amana 26 cu ft side by side quit cooling entirely in the freezer and the refrigerator. Is it worth it to get a repairman or should we just get a new frig. This one is 6 years old
I suggest get help with repairman.6 year old is not very old.Refrigerators have life more then 8 to 10 years.The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Oct 24, 2011 | Amana 26 cu. ft. Side-By-Side...
No ice cubes
Ice. refrigerator one year old.maker will not kick ice cues out
Oct 21, 2010 | Whirlpool Centralpark 25.6 Cu. Ft....
My refrigerator stopped cooling/freezing.
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Asker's Testimonial " Very helpful. Will give it a try and let you know outcome. Thanks!!!
Apr 08, 2010 | Maytag 21.6 Cu. Ft. Counter-Depth...
JBR2086HES - Jenn-Air
If it was buzzing then click, the click would mean that the thermal overload has activated. This would happen if the compressor is drawing high amperage due to a breakdown of insulation on one of the starter or run windings. What he says is very possible.
Mar 03, 2009 | Jenn-Air JBR2086HES Stainless Steel Bottom...
Jenn Air 48" Built In Not Cooling
the company that replaced the parts also should have changed the low side line and capiliary line it comes together as one unit
the capiliary line is partialy restricted
May 15, 2008 | Jenn-Air JS48SEFXDA Stainless Steel Side...
Refrigerators Logo
73 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
