Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Just got my 32" and am not clear on whether it can be connected directly to cable wire or if it has to go through the converter box. Thoughts?
    President:
  • 1,564 Answers
Yes it should be fed through the coverter box, otherwise you'll not be able to get any digitally enhanced channels. If it is HD you definately need to use the converter/cable box.
Posted on Aug 06, 2009
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
Conecting computer to view screen
Hello
Your JVC Tv has AV & Component video inputs only. No direct connection facillty with computer is there. Computers outputs VGA stream video. VGA stands for Vodeo Graphics Arrey. This video stream cannot be connected directly to your JVC set. There are sets, which have this facility, but your set have not.
If you want to connect this set to computer, you have to buy one converter [VGA to RCA out], from open electronic sparepart selleing shops at your town. It will not cost more.
If you have this converter, you can connect your computer directly to the VGA converter, using a VGA to VGA cable, and the output from the converter by RCA connecting wire to TV. In short, the converter will be in between TV and Computer.
VGA to Video converter will look somewhat like this. OK.
Dec 14, 2011 | JVC AV-32D305 32" TV
How/where do I connect tivax digital convert to my loewe Planus
The converter box has multiple ways to connect,but its really meant to convert a digital signal to analog. That's why the output channel for the converter is usually either channel 2 3 or 4 and you change the channel on the box rather than the tv. The box can be hooked up to the tuner which is the metal connector for antennas or cable. You can also use the composite hook ups as well (red and white audio, yellow video ) Just check which input on the tv your plugging them into so you know which to select for viewing. Signal out of the converter box,to video (av) in on the tv and you're good to go.
Nov 01, 2009 | Loewe Concept L32 Platinum 32 in. LCD TV
Dont have cable. i bought the analog converter, but read i don't
Digital Ready is not the same as having a digital tuner built in. Yours is probably the former and you do need a converter box: http://www.ezdigitaltv.com/HDTV_vs_HDTV-Ready.html
May 04, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Cable from converter box don't fit audio holes on back of TV
you need to buy some adapter radio shack sold him
Apr 24, 2009 | Televison & Video
Cable connection broke on back of tv
YOu will need a box that will convert your coaxial signal (cable) into a another using either Composite (RCA wires) or component (Yr,Yb, Yg) outputs. Your local radio shack should be able to accommodate you
Apr 01, 2009 | Philips 32PF9986 32 in. HDTV-Ready LCD...
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Want to use DTV converter with my Toshiba 32AF42
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
Dec 07, 2008 | Toshiba 32AF42 32" TV
Magnavox model 25TSC6 0101 able to get cable tv?
you should be able to connect the cable directly to the tv, do autoprogram from the setup/channel search menu.
Jun 13, 2008 | Televison & Video
Snowy picture and Yellowy Whites
Make sure the TV setting is set to or . A power surge may have reset your ?cable-ready? TV. Check the cable setting on your TV and make sure it is set to or . If a VCR is connected: * The VCR needs to be on channel 4. * VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. If a converter is connected: * Make sure the TV is on channel 4. * TV may not be ?fine-tuned? to channel Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * Determine if the converter is bad. Locate the cable wire coming in to the room and connect it directly to the back of the TV. If the picture is clear, your converter needs to be exchanged. Give us a call or stop by your local office and we?ll switch out your equipment. Check the fine-tuning of your TV
Jan 11, 2006 | Fujitsu Plasmavision P42VCA30EH 42 in....
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
50 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
