Question about HP 435768-001 - Compaq Presario C300 Series 15.4 WXGA LCD Display
My computer will stay on for about 3 minutes and then shuts off even when plugged in. It also has been shocking my wrists while i type.
  • 114 Answers
Normally this is new software windows doesn't like, or new hardware that has just been installed.
but to have shocks is new to me......if you can disconnect everything inside the pc. attach one thing at a time and then startup..........the only way to find the solution is to start eliminating things.
Posted on Aug 01, 2009
Samsung 46 inch LCD tv problem
AmanStino Mouse Pad with Gel Wrist Pad grey(9.0*7.8)
  • 1.Smooth and precise mouse tracking, Non-Reflective surface.
  • 2.Large round mousing area, Memory Gel Pillow keeps your wrist in natural position.
  • 3.Ergonomic design wrist support - Keep arms, wrists, and hands from getting sore while using the computer, reduce wrist stress and tirednes.
  • 4.Suitable for most optical, trackball, laser, and rollerball mi.
AmanStino Mouse Pad with Gel Wrist Pad black9 0 7 8 AmanStino
Feb 16, 2015 | Samsung LN46D630 46 inch LCD 630 Series TV
CASIO G-SHOCK 200 (G-7500)
The first thing I have to recommend it to unscrew it and remove the battery for a few minutes and then insert it back.
If this has solved your problem please rate this solution as "Solved" otherwise please ask us here again for more possible solutions.
Thank you :)
Oct 12, 2007 | Casio G-SHOCK 200M DW5600E1V Wrist Watch
Hi! When I shut my computer down the lights do not
When you shut off your PC do you:
1) Give it enough time (could take from 1 minute to 10 minutes) to shut down completely (easy sign is if the fun continues to run or lights are on)?
2) Clicked Hibernate or Sleep OR closed your laptop screen before it completely finished shutting down (this could put the PC to sleep and it would remain on, so the lights would remain on, until you woke it by moving a mouse, flipping the screen back and forth for a bit or pressing the start button (not holding))?
3) Have it plugged in (depending on the model, a light might stay on if it is charging even if it is not on(probably not this one since you said it turns off after a Hard shutdown (don't do this since this damages your computer and will make it break down after continued use)))
Nov 02, 2013 | HP Computers & Internet
MY EMERSON EVC1700 WONT CHARGE UP THROUGH MY COMPUTER. MY COMPUTER SAID IT DIDNT RECOGNIZE THE DEVICE. DO I HAVE A JUNK VIDEO CAMERA? what am i doing wrong?
turn it off befor ypu plug it into your computer if the cam is turnd on it will not charg unplug it shut it off and plug it back into your computer
Nov 27, 2011 | Audio Players & Recorders
I need to change the minutes to the correct time it is off by 3 minutes.
press and hold the adjust button, then the seconds blinks (blinking digit is changeable) press mode to choose for the minute to be change. when you are done just press the adjust button once. i hope i had been helped you.
Aug 12, 2011 | Casio G-Shock GW500A-1V Wrist Watch
My casio 2638 will not stay on, always in sleep mode, how long do i have to charge it?\
Chances are the rechargeable battery will need to be replaced, the average life span is 1 to 3 years.
Mar 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Dec 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I recently unhooked all cords to my pc and plugged them back in and the tower is not staying on
Sounds like one of the cards may have been fried or not completely reinstalled during the process. Did you wear an ESD wrist strap while you worked on it? Number one killer of hardware is static shock. Remove all of the cards while wearing a wrist strap and see if it will stay on. Did you ADD a new card?? Then your power supply probably needs an upgrade.
Feb 08, 2010 | eMachines T3642 Refurbished AMD Desktop...
Light
My watch had the same problem and i could never figure out what it was so i just lived with it for a couple of years. then, just recently even when my watch was getting plenty of sun the battery would die in the evening and shut off at night. so i replaced the battery and evrything works great. even the light which leads me to believe the solar panel is just a gimmick. i have an old g-shock watch that i bought in 1989 and it still works and is on the origional battery. my gw 300 is about 5 years old and needed a battery. i guess 5 years on a battery is prety good but i would rather have it last for 19 years like my old one.
Jan 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Setting time
push adjust.seconds will flash.then push mode until hour flashes.press split/reset to go down press start/stop to go up.press mode again for minutes and follow step 3.then press adjust to end.
Nov 10, 2007 | Casio G-Shock GW500A-1V Wrist Watch
HP 435768-001 - Compaq Presario C300 Series 15.4 WXGA LCD Display  Logo
90 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
