Question about Brother DCP 1000 All-In-One Laser Printer
Copy when the copy come out there is a white line on the right side of the copy
  • mdg7 Dec 24, 2008
    The white line is about 2.5" from the right edge of the paper. It is very thin, i.e., 1/16". Tried changing the drum and toner cartridge yesterday; the problem persists.
On the bottom of your drum there is a little green slider just pull it to the left until you hear it click.hope ths helps
Posted on Feb 28, 2009
  • rhall95 Mar 02, 2009
    well then i don't know what it could be.sorry
Hello, I got A Kodak i1440. I get white lines on the documents, when scanning on grayscale, the image guides are brand new. Any ideas on why is this happening and how to fix it? Thank you
green and white continuous forms WHOOAH!! the contrast is from the grayscale scanning. nothing you can do. maybe increase the contrast but the text will probably drown out. keep experimenting. try just a black and white copy and then try scanning the copy. could be a lot of work depending on your workload. have fun
Mar 10, 2014 | Kodak i1440 Pass-Through Scanner
A white line runs across each copy.
IF the whit line stays in the same place on every copy all you need to do is clean the left side glass this is called the **** glass i guess you have a top feeder if you place an original on the glass then do a copy you will not get the white line
Also check the developer unit has an even coat on the roller this will also cause the issue you are having
Feb 16, 2011 | Konica Minolta Office Equipment & Supplies
Thick black vertical line appears on the right hand side of the page
PLACE A PLAIN PIECE OF WHITE PAPER IN MACHINE AND TAKE A COPY. IF NO LINES ARE ON IT THEN THE LINES ARE COMING FROM THE MACHINE THAT IS SENDING TO YOU BUT IF U DO HAVE THE LINES THEN PRINT HEAD IS PROBABLY FAULTY OR DIRTY.
Sep 13, 2010 | Brother FAX-1020e Plain Paper Thermal...
Black line down right hand side how do i get rid
Open the original feeder of the fax and look for dirt on the platen(thin glass ) glass usually white out or postit glue clean with damp rag or isopropyl alcohol
Good luck
Apr 19, 2010 | Office Equipment & Supplies
I get lines and can't read the right side of copies that I make with the 1270e. How do I fix this?
You have not specified why you can't read the right side of copies and I am assuming that the reason is because the 'lines' are covering the text. I can offer a solution to the lines issue.
Most likely a fax has been sent or a page copied with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, scanning or sending a fax, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page. If this is the cause you will also find that faxes you send to other people will also have this line (although faxes you receive are not affected by this problem with your machine).
To fix the problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Feb 22, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Sent faxes have the right side cut off and black lines on side of paper, have cleaned white bar and glass cover....help
Sounds like the scanner section (the glass **** part in the original scan section). These are notorious for going out and sending partial black or all black pages. Try making a copy and see what it looks like, but if it's sharp lines on (across) sections of the copies, then that's what it is. It's about a $40 part and easy to change. Just lift the "tab" on the holders right side....slide the unit to the right...lift up the left section...pull it out and unplug it. Be carefull not to let the connector fall into the slot it came from or you'll have to disassemble it further or fish it out. Replace in opposite directions.
Oct 22, 2009 | Brother IntelliFAX 4100 Laser Fax
Copies have a white streak near right side of copy canonpc920
PULL OUT THE CARTRIDGE AND SHAKE IT, IF THE COPY IMPROVES ITS OUT OF TONERAND NEEDS REPLACED
Apr 07, 2009 | Canon PC-920 Black and White Copier
Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Jan 12, 2009 | Dell 1710 Laser Printer
Lines on copies
The lines are caused by some debris that is on the platen (the glass where you normally place the copies). The usual culprit is white-out smudges from a copy that wasn't completely dried yet. When you make copies using the feeder, the roller passes the paper being copied over a little section of the platen (if you pull up the feeder "lid", it'll be on the right-hand side of the big glass... it might even be marked with 2 green arrow stickers, but if not, it's the part of the glass directly under the roller of the feeder). You can just take an alcohol wipe or soak a cotton ball with alcohol or windex and wipe down that strip of glass under the roller.
Jul 01, 2008 | Canon ImageClass D861 Printer
Brother DCP 1000 All-In-One Laser Printer Logo
75 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
