Question about Whirlpool WFW8300SW
NEED bearings for washer. Where do I find the parts??
I have the whirlpool duet sport washer. Bearings wore down to dust. I know I'm going to have to purchase some new parts. Where can I find parts for this washer? I am looking for the bearings and a seal. model # WFW8300SW02
  • 42 Answers
Call 888-474-8362. Provide them with a model number and the parts you need and they can ship it out that same day if in stock. :)
Posted on Aug 01, 2009
What causes this machine to squeal while running?
I had a similar issue, had a bad bearing. A quite frequent failure int this device. Only way to diagnose is dismounting it
These are not properly your model but see some videos how to do it:; might help to understand the job
How to Replace Washing Machine Bearings
Repair HE3 Washing Machine Bearing Noise
ApplianceRepairVBlog 2 Replacing the rear bearing on Whirlpool Duet...
Duet Whirlpool Sport Changing Bearings
Aug 02, 2015 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet front lading washer, GHW9150PW4
Could be drum bearings gone Quite a big job hence costly with around 3 hours labour plus parts, some models need half drum as the bearings are loaded in here,leak could be door boot seal at 7 yrs old not sure if worthwhile as its about the end of its working life.Good luck
Apr 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer has begun to sound like a four wheel drive vehicle going down the highway at 60 mph. The matching dryer had been squeaking and now has begun a thumping sound.
if it sounds like a jet plane taking off its the drum bearings and you need to replace these bearings,if your lucky you can find just the bearings and lip-seal,if not you will need to but the tub with the front bearing installed already and this gets expensive,otherwise to just replace these bearings and seal alone its about $500.00 to $900.00do it soon as the longer you wait the more labor intensive it gets
Aug 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
the drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
May 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When the washer spin it has a load noise, it sounds like a plane is comming down. I have a duet sport whirlpool washer
the bearing probably went bad, thats the sound it makes, may even sound like a freight train at times.
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Whirlpool Duet WFW9200SQ02 - high speed spin extremely loud!
I have the exact same washer, its also 2 years old, and this last week my bearings went bad too. I actually pulled my washer apart and replaced the stock el cheapo bearings with some better quality ones by Toyo. No, theyre not titanium, I'm a mechanic and I've never even seen titanium sealed bearings before. Not doubting they exist, but I highly doubt youll find them in any residential appliances regardless of make. Upon disassembly, I found what I believe is the issue with the seal, hair. Hair works its way to the drive shaft, slowly works its way into the seal, and then acts as a conduit for the water to enter the bearing cavity. Both sealed bearings eventually have thier grease forced out by water, and fail. This repair is time consuming, but it can save you a LOT of money. Whirlpool only sells a whole new rear tub, at a cost of $408 just for the part. I took it apart and found that the bearings are simply pressed into the steel hub on the rear tub half. I knocked them out, and a local bearings and drives shop had some replacements for me, for $20. I put it all back together, and its running fine. If you attempt this repair, make notes, and mark where everthing goes. You'll need to disassemble a substantial amount of the machine to get the tub assembly out. If youre not able to do the repairs yourself, I recommend buying a new washer, its just not worth spending $6-700 to have a shop do it.
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150W0 Washer - Stainless Steel Washer Bin Arms Broken
I HAD THE SAME PROBLEM. I CALLED THE 800 NUMBER AND HAD WHIRLPOOL SEND ME ALL OF THE PARTS THAT WERE STILL UNDER THE EXTENDED WARRANTY THAT I PURCHASED. WHIRLPOOL SENT ME EVERY PART, INCLUDING THE STAINLESS TUB, THAT WAS STILL UNDER WARRANTY. I NOW HAVE REPLACED ALL INTERNAL PARTS EXCLUDING THE MOTOR.
Jun 07, 2009 | Whirlpool GHW9150 Duet Washer
"whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose"
You have a big problem here. It sounds like the bearings on the drum shaft are going. this is over $400 for the back half of the outer drum and you have to be a very good mechanic to get it all apart. I currently have mine apart for the same problem which I verified by opening the door of the washer and lifting the inner stainless steel drum up and down with the machine off, of course. The tub is supported by two large ball bearings on the shaft that is supporting the stainless steel drum, and they don't sell just the bearings and seal, only the back half of the drum. If it has gotten bad enough to rub against the front half of the outer tub, it will probably have to be replaced also, about $120. This was probably caused by overloading the washer or washing something that was unbalanced and heavy; this destroys the seal between the inner drum and the heavy bearings, also not available separately, and lets water into the bearings in the aft outer tub which support the inner tub shaft. If you want to try to take this apart to verify, try looking at Whirlpool consumer services technical education group presents #L-68, Job Aid Part No. 8178076. I found it online. It has detailed instructions how to take this machine apart if you are a technician or a talented amateur, as I am. Good luck.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader staining..
i have the same washer and i am some times perplexed about stain that appear after washing> i always blamed colors tranfer from other items .I'll keep a closer eye and see if i can find any more. does your washer have any oders that bother you mine does. for the price i feel cheated
Mar 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8300SW Logo
328 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
