My steam oven is stuck requesting a descale and will do nothing else. The descale appears to start for a few minutes and the clock times down, but then it asks for water and descaler again and resets the clock. I cannot exit the mode.
I have the exact same problem. Did you ever find a solution? Thanks.
Press and hold the timer button (the bell picture), and whilst doing that press and hold the power button. Then let go of both at the same time. Then press the timer button 5 more times, but on the fifth time hold for a few seconds. Once in Programming mode play with the options to reset and restart descaling.
SOURCE: how do I descale a Miele steam oven?
Put the tablet into the steam generator with about 1ltr of cold water, select the cleaning cycle on your oven. let it go through the cycle.
Hope this helps
SOURCE: miele steam oven keeps wanting to be descaled after descaling!
Ours does too. Did you ever get it fixed?
SOURCE: I was getting a small
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
