Question about Refrigerators
Kenmore refrigerator quit working about 5 days after move. It froze some frozen vegetables after move, but then it would not cool at all.
  • 42 Answers
If the compressor does not kick on check the start relay attached to it. If you shake it and it makes a noise as if stuff is loose in there, it's broken.
Could be freon loss do to moving.
If the freezer side is iced up then its your defrost parts that are wrong.
Posted on Aug 01, 2009
I have a Kenmore Coldspot refrig model 106.53332300 that quit cooling and freezing. Seems normal except for a faint, periodic high freq sound. Anything I can do before calling repair person?
Move food to coolers and if you can borrow space in friends freezer move frozen food there. Call for service from any reputable repair company.
Apr 23, 2018 | Kenmore Refrigerators
Kenmore fridge, 59665932403, Froze up.
Could be an ice buildup behind the fan, in the air passageways or around the fridge thermostat.
Could also be that the DEFROST thermostat needs to be replaced.
Sep 09, 2016 | Kenmore Refrigerators
What would be the problem if refrigerator become a freezer.......all my vegetable and stuff that should stay cold become frozen ....I have a Kenmore elite top mount refrigerator which I bought 5 years...
this can happen when your ice can start to block vents ...try turning off your fridge for 2 days so any ice blocks that have formed can melt right down , then switch back on ....should do the trick
Oct 19, 2010 | Refrigerators
Refrigerator part quit keeping food cold in last day. The freezer compartment has everthing frozen very solid; more so than before and the motor keeps running. Pulled the refridgerator out and cleaned...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Kenmore 65234 Bottom Freezer Refrigerator
My Kenmore side bt side isn't cooling. The
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 98d4754.jpgIf this was a slow moving loss you should clean the cooling coil under the refrigerator. Remove the bottom snap in grille and vacuum out the dirt and dust from the coil and anything else you can reach. You may need to make an extension with paper towel tubes flattened a little and tape to get into the cramped spaces. I use a piece of clear plastic pipe stuck in the suction with a long angled split cut on the cleaning end. Maybe also move the fridge out, vacuum and clean the flooring area also. (And every 6 months)
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Refrigerator/freezer has stopped cooling
Sounds like you need a new relay for the compressor. Unplug from wall and check the compressor see if realy that is attached to pins on compressor, is burnt.
Apr 05, 2009 | Kenmore 53082 / 53084 Side by Side...
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Runs 90 percent of the time Kenmore s/s 57262791
Hello! panda1,
You are fine, if all is working, just leave it, and enjoy it.
Problelms that may arise: After adjustments, ice cream to soft; milk to warm, vegetables frozen, eggs frozen, temperature not controlled. Typical of this units.
Since this is a energy saving unit, It tends to use more energy being that the compressor is low rated. The evaporator fan runs a lot, the defrost cycles run multiple of times, noisy, grumbles, and can keep you awake, if one keeps a ear to it. Just forget it. Once in a while, look at the bottom of the freezer, move some items, look at the coil , in back, an see if there is any ice build up, Some is ok. It should be clean, clear after a defrost cycle. (See input from peyton32034) may be additionally useful.. Regards, fmauka
Dec 23, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
