Question about Samsung HL-P5063W 50" Rear Projection HDTV
Hlp5063 no picture, have tested and replaced....
Todays date: 07-31-09. As to some of the other postings, my tv never gets a picture. It does turn on. Here is what I have done so far: I've replaced the bulb and the ballast. Same problem exists. I can hear the color wheel spinning. I am concerned that one of the two parts I've replaced is also bad. Does anyone know how much voltage the ballast should be putting out to the bulb. my multimeter is only showing a little over 13 volts. Also, is the small pigtail wire going to the ballast a switch that turns it on and off? If so, what is the part on the other end of that wire. Jeff M. jeffscottmendoza@yahoo.com I am not going down without a fight with this TV!!!!
  • jeffscottM Aug 01, 2009
    To clarify, 3 lights do blink on power button. When ballast fires, it fires at 183 volts and levels at a little over 13 volts. Does anyone know how much it takes to ignite the bulb? Is 183 volts enought?
  • jeffscottM Aug 10, 2009
    I may know what the reason is for the problem, thanks to a tip from Sparko1, thanks Sparko1, but I haven't had time to confirm this. During the period of 1997 through mid 2000, there was a taiwanese company that stole another companies formula for capacitors. I found an article on the web explaining about this company and how when it obtained the formula, they didn't have the correct formula for cooling them, so they improvised and started manufacturing them. This is the same time frame that these samsungs were built. I'm not sure if this is the reason, but it fits the picture. What happened to the products manufactured, the capacitors started mushrooming, leaking and in some cases literally exploding. When I get the time, I'm going to pull all the boards out and first visually inspect them. If this is what is going on, then samsung should of recalled all of their products like many other companies did. This probably would of caused a major hit to the company. It would be easier to just give the run-a-round to the consumers and hope to avoid costly recalls. This would explain perfectelly why my ballast is only putting out a minimal charge to the lamp.
    Jeff
  • 167 Answers
The Ballast voltage should 300 volts. You may have a problem on the power board. Possibly some bad capacitors. Look for the tops of the capacitors to be domed instead of flat.
Posted on Aug 01, 2009
Samsung hlp-5063w no picture when its on
Do you have three flashing lights on the front? You most likely have a problem with your lamp or color wheel. Those two component combined are pretty much the guts of your TV. If you are handy, you can replace those parts yourself. I have a 50" Samsung DLP and I've already replaced those to items myself. Otherwise, you can contact Samsung at 1-800-SAMSUNG and they can assist.
I bought my parts using Amazon, had them shipped to me, and took an afternoon to take about the back of the TV; documenting everything and taking photos of the progress, until it was done. There may be video tutorials on Youtube. There was for my model (HLS5086). Here is a great link to help you along. Good luck.
http://blog.trebacz.com/2011/01/50-samsung-dlp-hl-p5063w-with-3.html
Nov 19, 2013 | Televison & Video
I have a Samsung HLP5063 DLP tv. After replacing the bulb and cleaning the inside of the TV, the picture is out of focus on left side and in focus on the right ( varies slowly across the screen). Does...
If you wish to get some details about this, check the site linked here. Adjustment to be done after lamp replacement to DLP TVs are given in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Samsung DLP HL-P5663W 56" TV
Sony tv picture goes green
HAVE IT REPLACE WITH A NEW ONE
Sep 12, 2012 | Sony Internet TV NSZGT1
Hlp5063 tv look like jail bar picture
Check light tube in engine, make sure mirrors are intact and didn't slip.
Nov 07, 2011 | Samsung DLP HL-P5663W 56" TV
Krups XP7200 series date problem
It seems that the dial knob and the electronic opto coupler don't work anu more. You can replace the digital panel by try to find a broken machine on ebay. Unless you are an electronics engineer like me (you can try to replace the optocoupler). See the post on leaking xp7240 for opening up the machine... it's tricky but easy.
Apr 14, 2010 | Krups XP7230 Compact Super Automatic...
Live tv mode how do I turn it off
Hi taniabusby there seems to be a couple of issues here. Thefirst one seems the Software may be out of date, the current software as of 1/18/11is L6.73, L6.72 and L6.71. If you are running the current software then youwill need to run a Check Switch Test, this test will acquire the strongestsignal and will allow your guide to update fully. I will send a link to helpget your full guide to show.
http://www.dishnetwork.com/SupportSection/no-guide
Mike Houston of DISH Network
Apr 01, 2010 | DISH Network ViP722 DTV Receiver /...
Samsung HLP5063 the blue and green seem misaligned
you have what they call guns in the back of the tv blue/green and red and sounds like they have came out of adjustment. as far as the picture being black and white you should get a tv technician to check it
Aug 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hlp5063
That means that the color wheel, ballast and lamp are working properly. It seems more like a video source failure or one of the thermal sensors that is mounted on top of the color wheel assembly.
Will keep you posted about my findings with my TV.
Aug 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
No picture on my hlp5063
you might need to replace the lam anyways. if you looking the back do you see light through the vents when you turn it on??
32 wega trinitron
surprised it went 12 most 8-9 not Worth the fix
Apr 17, 2008 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
253 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
