Ilo tv model lct27ha36 does not go from standby to on
  • patfnorris Aug 10, 2009
    we are not capable of taking the back off the TV
    ilo tv does not go to on (GREEN) from (RED)
    via remote or manual turn on button
    on vacation last week came home plug in tv and it came on has not came on since we turned it off Sat. night.
  • 3,741 Answers
This happens when 1)If the power supply board is having short circuit in the circuit tracks.due to this the flow of current gets hold where there is short and so circuit does not gets completed and tv does not starts. 2)if the component on the power supply board or the main board gets shorted the tv does not gets on.
As you say it remain on standby mode but does not goes to on.this means the whole power supply board is not faulty.it is any of the component blown on the board or there is a minute short circuit on the power supply board.this has to be checked by multi meter to locate the faulty components. This short circuit actually causes due to major power surge occured while the tv is ON or due to humidity the moisture gets collected on the main board.and when you ON the tv the wet drops of moisture collected on the circuit board sparks when the current passes it shorts the component. The other reason of this can be loose wire connected.remove all the external wires connected to the back of the tv.also remove the main power cord of the tv.then only connect the tv power cord and ON the tv and check out. There is also a reset method that is keep the tv unplugged from all the power outlets for more then 4 hours.then connect it and check.in this what happens that all the settings gets resetted as per the manual. -------------------- check out and reply.will be always waiting to help you.when ever you require more help.please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Aug 10, 2009
    President:
  • 2,185 Answers
Are you doing this thru your remote? Did you try to manually turn it on thru the button of your tv?
Posted on Aug 01, 2009
    President:
  • 2,185 Answers
The most common cause of this symptom in this particular Ilo model is a capacitor/s that failed in the power supply board of your TV. These capacitors can be visually located because they are usually vented or BULGING. The only way to verify this is by taking the back cover off your TV.
I hope I was able to help.
  • virtualhost
    virtualhost Aug 05, 2009
    Hello there PatFNorris,
    Just wanted to follow up if you were able to solve your problem already?
2 Suggested Answers
  • 146 Answers
SOURCE: ILO TV remote
order the factory remote.800-216-5156
Posted on Mar 20, 2008
Model number LCT27HA36..will not turn on????
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to jah2mil@hotmail.com if you required further assistance.
Aug 17, 2009 | iLO Televison & Video
27 in.lcd tv ilo power wont come on using remote, or set button?
lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
Oct 01, 2008 | Televison & Video
Sony RMV210 Remote Codes for iLo LCT27HA36
Salutations Schaf1,
This happens with some manufactures. Thankfully some codes will work with other TV's. This is the "Code Search" starts. Your remote has a way to try other codes to see if they will work.
If all else fails it appears Sony has a support hot-line available at 1-800-822-2217 that maybe able to help you find the code. Just make sure you cover all the troubleshooting steps you've already done.
Hope you find that code.
Jon
Go Ahead. Use Us.
May 06, 2008 | iLO LCT32HA36 Television
Ilo lct27ha36
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Apr 01, 2008 | Televison & Video
ILO TV remote
Mar 20, 2008 | Televison & Video
Ilo LCT27HA36
Contact the manufacturer or go to their web site for manuals etc.
Feb 02, 2008 | iLO LCT32HA36 Television
ILO LCT27HA36 No Manual
This is a very low end low quality made TV set. I would suggest you take it back and see if you can exchange it.
From my experience, I would suggest getting a good quality brand name TV set. Most of the Sony LCD TV sets have earphone jacks, external outputs, and come with a full set of instructions. They are also strongly supported for service during the warranty period.
Jerry G.
Oct 15, 2007 | iLO LCT32HA36 Television
Ilo lcd tv lct27ha36
I having the same problem. Called the company $80 for a new remote. I only paid $300 for the TV. The company said they have not given out the code for the television. What a CROC! Like the TV, but probably won't buy another.
Sep 23, 2007 | iLO V27DMBX Television
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
