Question about HP PhotoSmart 7150 InkJet Printer
Printer does not pick up paper. grinding sound on
Printer does not pick up paper. A grinding sound is made on left side. The paper feeder wheels turn, but paper is not lifted up to feed the paper into the rubber wheels.
  • 26 Answers
Please perform the steps given in the below document and check for results.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en&product=72881
Wish
Posted on Aug 01, 2009
EPSON PX660 Display load paper but when i load paper the feeder does not roll/pick up paper the paper
Make sure it's not jammed with paper then follow these instructions for loading paper.Power unit offOpen the paper support, then slide out the extension.
Open the front cover. Next, slide out the front tray extension.Make sure that the tray lever is in up position.Slide the edge guide to the left.Fan a stack of paper, then tap it on a flat surface to even the edges.Load the paper with the printable side up, against the right side of the sheet feeder and place it behind the tabs. The printable side is often white and brighter then the other side... if using non-standard A4.Slide the edge guid against the left edge of the paper, but not too tightly.Power unit back on.
Nov 17, 2011 | Office Equipment & Supplies
Hi My epson rx620 keeps feeding paper on angle. when i take out paper there is a dent on the leading edge which seems to indicate an obstruction about 60mm from left hand side stopping left hand side of...
Top loading printers often get items falling into the paper feeder. Check for blockages and try using a vacuum cleaner hose with a narrow attachment to clean any rubish out.
Mar 16, 2011 | Office Equipment & Supplies
Feeder is no longer feeding. What should be
Well I don't think you are going to be able to find replacement parts for it. But what you can do is try the following. Turn off the printer, unplug the power cord, remove any paper that you may have in the feeder now pick up the printer and flip it upside down. Be careful with the scanner lid but sometimes what happens is that things will get inside the printer blocking the paper path. That will cause the printer not to pick up the paper most of the time.
Jan 09, 2010 | Lexmark X5470 All-In-One InkJet Printer
1320 HP Laserjet Still Won't Pick Up Paper
Please check limiters paper in tray 2 to be on A4, letter, depending on paper format. Otherwise you have problems with taking the sheet from tray 2.
Oct 09, 2009 | HP LaserJet 1320 Printer
Lexmark X2350 won't pull paper to print.
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Press the "Power" button to turn the printer power off.
2. Press and hold the "Copy" button.
3. Press the "Power" button one time and release it(keep holding the copy button).
4. Let go of the "Copy" button after the power LED flashes once.
5. The self-test will produce 1 page. The test is not continuous.
The self-test should print out a set of black and color bars.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 11, 2009 | Lexmark X2350 All-In-One InkJet Printer
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Dell 5200 printer won't pull from MP tray
open the lower front cover at a 35degree angle and pull up to remove this lower front cover remove the toner. slide the upper deflectoer to the right and remove it. under this deflector on the left side is a pick wheel on the right side of the wheel there is a locking tab push on this and pull the pick wheel off. spray a rag with cfc contact cleaner and rub this wheel with it to remove the buildup. this will solve the problem
Oct 21, 2008 | Dell M5200n Laser Printer
False paper jam
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 25, 2008 | Dell 922 All-In-One InkJet Printer
EPSON R1800
Clean the rollers down where the paper sets in the printer. Do not use cheap generic matte coated paper. Some generic matte coated paper will leave a film on your rollers and cause them to not grip the paper.
Apr 14, 2008 | Epson Stylus Photo R1800 InkJet Printer
Paper Mis-Feeding
Check for any pieces of torn paper in the path, especially on the left side. You can also reach into the slot that the paper feeds into and feel each of the rollers behind the plastic cover; they all should turn freely, pay special attention to the wheel to the left.
Mar 25, 2007 | Canon i850 InkJet Photo Printer
HP PhotoSmart 7150 InkJet Printer Logo
303 people viewed this question
Seeker5211
Seeker5211
