Question about Acer Aspire One Netbook 8.9" Notebook
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right buttons next to the touchpad function normally. Did I inadvertantly do something to change the touchpad function? There's nothing in the small manual that came with the computer to cover this situation. Thanks for the help. Carl
  • cskpuels Aug 01, 2009
    asoveral, Thanks for the help, however, can you explain where I find the Settings tab? I'm a bit new at this. Carl
    Novelist:
  • 157 Answers
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Posted on Aug 01, 2009
    President:
  • 566 Answers
To adjust touchpad settings, click on Settings tab, Touchpad, then on the Tap tab and check the Activate Tap checkbox.
You can also adjust the touchpad sensibility in GeneralTab
  • A Soveral Aug 01, 2009
    What system does your ACER ONE have installed? LINUX or WINDOWS XP?
Toshiba Laptop left click stopped wokring?
1) Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature.
  • 2) Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results.
  • 3) Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked.
  • Feb 06, 2012 | Toshiba Satellite L505-S5966 Notebook
    My Acer Aspire 5732z inbuilt mouse works and stop, why?What is the solution to this problem?
    Hi faithfulnice...
    To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
    This process is different for each computer manufacturer.
    If unsure which Function key enables and disables the touchpad, try each one at a time and then
    attempt to use the touchpad after each one.
    A...Locate the "Fn" key of the laptop keyboard.
    The "Fn" key has different colored text or the key is a different color.
    B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
    The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
    C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
    Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
    Note: Mac computers use "F2" to enable and disable the touchpad.
    D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
    Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
    Please take time to rate me thumbs up
    Sep 11, 2011 | Computers & Internet
    I've just bought a new Acer Aspire 5742Z and the smart pad has suddenly stopped working. Any idea whether it's likely to be a hardware or software issue and how to fix it? I've tried...
    Hi jennylewry...
    Sep 10, 2011 | Acer Aspire One PC Notebook
    When I click once using my touchpad left key, it does the function as if I had clicked it twice. What should I do to stop it??
    got to control panel and look under mouse/pointer options make sure it has not been switched to treat single clicks as double clicks
    Oct 06, 2010 | Dell F3534 Touchpad
    My touchpad will not respond when I tap it anymore. I have to use the left button. I used to be able to tap or double tap the touchpad and it would act like the left mouse button. All of a sudden it...
    On the bottom bar by the clock, if your computer is newer there should be a small icon that controls your mouse. Simply right click on it and check the box "tap to click" or similar. Hope this helps!
    Please rate me if i am helpful.
    Thank you.
    Yboyandrei
    Aug 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
    Acer aspire one touchpad right button not working
    you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
    Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
    How do you change from a single to double click on the pad of my laptop so that in a moving truck I am able to control the computer
    I am not sure if you're asking about how to change the settings to make a single tap on the touchpad function like double click. You can go to control panel>mice or touchpad.
    If you're just asking how to do double click on the touchpad, by default, it's set to tapping the touchpad twice. You can change change the speed settings in control panel too.
    Oct 05, 2008 | Toshiba Computers & Internet
    Touchpad in Acer TravelMate 2350 stopped working
    hmm... goto control panel, double click on mouse icon
    click on Device Setting tab and Click on Enable button and finally................. :))
    Thanks
    Iqbal
    Apr 01, 2008 | Acer TravelMate 2300 Notebook
    Touchpad Not Working
    is there a touch pad 'switch' off function with this particular model? Some Acer machines have an F number plus another key to de-activate/reactivate touch pad. Check your Manual
    Jun 19, 2007 | Sony 4-660-223-01 Touchpad Keyboard
    Acer Aspire One Netbook 8.9" Notebook Logo
    1,124 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
