Question about Car Audio & Video
I have an Audi A6 1995 with the infrared keys. I can not make the infrared to lock or unlock the doors. I believe I have to reprogram the alarm module to meet the same code, but I don't know how. My keys are new and also are the batteries.
  • Flavio Fraga Aug 12, 2009
    Hello Taran.
    I tried this procedure before, but was unable to achieve success.
    I don´t know if it is the alarm module or the IR wiring. When I lock the car with the keys the alarm works fine.
    Can you help me to find the alarm module?
    Thank you.
  • 10,865 Answers
Yes you must reprogram. If you do not have the instructions on reprogramming go to an audi dealer and ask them to pring off a set for you.
Posted on Aug 12, 2009
  • 10,515 Answers
As per the manual :-
Do you have memory seats as well? If so follow these steps I am going to refer to the keys as A and B as you have 2 of them
1) Unlock car with key A
2) Turn ignition into ON position with key A and roll down the window
3) Point Key B at IR Sensor and Click twice (perform both clicks under 5 seconds)
4) Turn off ignition and pull Key A out
5) Turn ignition into ON position with Key B
6) Point Key A at IR Sensor and Click once
7) Turn off ignition and Pull Key B out
Key A should be programmed as the Master Seat Program and Key B should be programmed for the Secondary seat program
So when you set your memory seats Key A is for Memory Position 1 and Key B is for memory position 2
if you don't have memory seats then you only have to point the receiver at the sensor and click once. That should just sync the IR Frequency and Codes
Hope i helped.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 01, 2009
Audi TT alarm won't quit going off
Get out of Car and use the key to lock Drivers door and then use key to Unlock drivers door, You someytimes have a switch built into the door lock it self.. Good luck
Oct 21, 2013 | Audi Cars & Trucks
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
I replaced battery in my audi 80 2.0 tdi but have lost the remote and alarm wont stop going off .
Depress lock or unlock button. Manually lock and unlock driver's door within 30 seconds. System should now lock or unlock vehicle. If not, carry out programming procedure.
Programming
When
Key added or replaced. System malfunction: Alarm LED in rear fog lamp switch illuminates for 30 seconds when vehicle is locked.
How
NOTE: A maximum of 4 keys can be programmed (one at a time).
As memory positions of existing keys are unlikely to be known: Obtain and reprogram all keys.
NOTE: Existing key memory positions will be overwritten.
Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Using first key, press unlock button once (programs memory position 1). Alarm horn sounds once to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF. To program remaining keys into memory positions 2, 3 and 4. Carry out the complete procedure below for each key: Switch ignition ON. Use key not fitted with remote control. Manually lock vehicle using key. Press unlock button at 1 second intervals, as follows: Twice for memory position 2 (second key). Three times for memory position 3 (third key). Four times for memory position 4 (fourth key). Alarm horn sounds once every time unlock button is pressed, to indicate signal received. Wait 6 seconds. Press unlock button once to confirm programming. Vehicle unlocks. Programming mode deactivated. Switch ignition OFF.
NOTE: Ignition MUST be switched OFF between each key programming procedure
Jan 10, 2010 | 1992 Audi 80
How to reprogram key for audi tt 2000 just replaced batteries got spare key hav tried puting spare in ignition the other key in door lock and pressed unlock but no lights flashed
if you have just replaced the batteries this procedure should work if not get back to me and we will try the next step.................
manually lock and unlock drivers door within 30 seconds
system should now lock and unlock vehicle
Oct 31, 2009 | 2000 Audi TT
Audi A6 Anti Theft Central Locking Tantrums
Sounds like you are having problems with your built-in alarm system. Like most systems in your Audi, you can read the error codes stored in the controllers. It takes a tool normally only a dealer has (VW or Audi) or an adapter like the VAG Com. (Google it)
I also think you can disable the alarm system and just use the key.
Could the lock button on your remote be stuck? Use a different key/remote. (leaving the suspect key at home.) The keys/remotes can be taken apart....
Sep 02, 2009 | 2000 Audi A6
How do i shut off the alarm on my Audi 100 s 1994?
Ok this is audi own alarm and was fitted as standard, alarm is found in the back of the car, and is oporated when you lock the car with the key. So it could be a control box fault.
Aug 12, 2009 | 1994 Audi 100
Try to reprogram the keyfob went through the guide put key in the ign lock door with other key wait 5sec and so on at the end of the sequence it unlocks the door nd the indicators flash take key out of the...
I recently changed the batteries in the key of my 2001 Audi TT. To reprogram it, I needed to take this 1 key to the vehicle, click on the unlock button and within 1 minute, open the driver side door manually with the key. It worked.
Jul 10, 2009 | 2000 Audi TT
Locking mechanism is broken on driver's door.
If the valet key is not programmed to the Immobilzer system, it should start the car, but it will shut off. This is only if the car has an Immobilizer system. If your locksmith unlocked the car without the door key, then use the key to unlock and disarm the alarm in the door. If you triggered the alarm, the starter will be disabled till a unlock signal from a remote or the door is actually unlocked with a key. If that cannot be done, your only solution right now is to tow it to the dealership and have them make a master key and check the door locks for proper lock/unlock commands so the alarm will arm and disarm correctly.
Apr 25, 2009 | 1998 Audi A6
My infrared remote does not work. I have an Audi A6 1995
Feb 17, 2009 | 1995 Audi A6
Program a remote key for 03 A6
I have an A4 and did this to re-program my key:
1. used the key to start the car...then turned it off
2. put the key in the driver door (door closed)
3. pressed the lock button on the key fob once
4. turned the key to lock the door.
This is basically the steps in the owners manual, but the car must be started with the key first, and the key must be in the door lock before pressing the lock button.
Dec 10, 2008 | 2003 Audi A6
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
