Do both hoses go outside? It now has one inside and is leaking water on the carpet.
  • 1 more comment
  • holdahl Aug 01, 2009
    soleus air 10,000 btu dehumidifier heater and fan
  • holdahl Aug 02, 2009
    This is a stand up indoor unit with 2 hoses. How should it be hooked up properly?
    Also there is not a drain pan.
  • 10,515 Answers
There might be many reasons for the same. A guide has been given which explains 6 major reasons for ac leaking ( Including Window and portable one ) :
http://searchwarp.com/swa70216.htm
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 03, 2009
  • 5,660 Answers
Yes both hoses should lead outside. Condensation naturally forms inside an air conditioner. Air has moisture, (Water), in it. As warm air cools the molecules of the air condense, and the moisture is released. There are drains in the bottom of the air conditioner to catch this released moisture, and hoes that lead the moisture to the outside of the home.
Is the hose long enough to lead outside? Can you lead it outside in the same fashion as the other hose? Does the outside of the air conditioning unit, lean slightly down on the outside? It should have a little bit of a pitch.
Looking at the side of the air conditioner, the front is inside the house. The back is outside. The back should be tipped down about 1/2 inch.
Posted on Aug 01, 2009
  • joecoolvette
    joecoolvette Aug 02, 2009
    That's Different! I should have asked for clarification.
    Is it a Soleus Air MAC-10K?
    http://www.a14electronics.com/Soleus-Air...
    Here is a different model of a Soleus 10,000 BTU, dehumidifier/heater/AC unit,
    http://www.hvacsolutionsdirect.com/files...
    Familiarizing myself with the design, and function of the Soleus portable dehumidifier/heater/AC units just now, I see that when the AC function, (Air Conditioning), of the unit is implemented, the large plastic flexible hose, has to be mounted to a plate which resides in a window opening.
    I also see that when the unit is used in an area which has a lot of humidity, there is a small hose which leads to a drain pan underneath, or can be lead to an outside source.
    According to the PDF file above for the Soleus PH3 10R 03 Model, the Control Panel for this unit has a display, that will light up when this drain pan is full.
    It would seem that your only recourse, is to constantly drain that pan when it reaches the full mark, or implement some way to install a long hose, and lead it outside.
Aircons with 2 hoses normally do need to go outside. Please provide the make and model of the unit to confirm.
3 Suggested Answers
dvs_redstorm
  • 81 Answers
SOURCE: I have the super cool have hose outside window
make sure the water hose is running down hill and can flow easly is there some water coming out of the hose and the rest from the unit . you will have to take it apart and check the hose clamp it tight.
Posted on Nov 11, 2010
  • 4736 Answers
SOURCE: MY AC IS LEAKING UNDERNEATH
After reading your post, it made perfect sense. In your situation, you don't want to use water to clear the PVC pipe(s), you should use compressed air. Which is what most HVAC technicians use. If you know someone that has a portable air compressor, that would definitely do the trick. You would do all this from the outside, rather than the inside.
I hope this helped you and thanks for choosing FixYa.
Posted on Jul 24, 2011
The drainage from the windscreen has become blocked causing sodden carpet on front passenger side.Where are the points for clearing these drains?
Even without knowing what kind of vehicle you are talking about and I wish you would have said which it is there are rubber hoses that connect to those front outside by the windshield drains in those hoses deteriorate especially on foreign cars and start to leak inside the vehicle you need to replace those hoses that are deep under the dashboard they're normally supposed to send the water from below the windshield and wiper area outside the car I had an Alfa Romeo that did the same thing the Rubber deteriorates and lets water come through replace those hoses
Mar 17, 2018 | Cars & Trucks
Much water under front carpet of 2002 Toyota Sienna. seems to coming from up under dash on firewall I think, what say you.
If the Water smells like Antifreeeze then it is your HEATER CORE
If the water smells like Water or Dirty Water, then you have a LEAK.
Here is a TRICK..
Get an Aresol Can of WINDOW CLEANER.... Spray completely around your Windshield on OUTSIDE EDGES... YOU WANT IT FOAMY.
Get an AIR HOSE and BLOW the Windshield from the INSIDE and see where the leak is coming from.....
It has ALWAYS worked for me
Apr 08, 2013 | 2002 Toyota Sienna
1997 Olds ** watr leaking into floorboard. By searching all over google- i found a few situations where this car has a "wheel well" problem of throwing water from tire up into wheel well which...
No, you would need to replace the well but it sounds like this is not the problem, most of these that rott are visible with a light shining from outside in with trunk carpet removed from the sides, i think your problem may be in the front area. try sparing with a water hose, no pressure hose, spray around windsheild and see if it leaks inside, another thing to check is the heater box drain, theres a small hole coming through firewall that comes from the heater box , this drains water from ac and wtare that gets into box and drains it outside, check that to make sure its not plugged. if you notice the water after it rains then its not the heater box but check it anyway.
Mar 19, 2011 | 1997 Oldsmobile 88
Im getting water under my carpet on the drivers back rug.alot.mold is growing.also when i open the driver front door i see water on the jam.is that sunroof related or door related?
Best way to check is with someone on the outside with a hose and someone on the inside looking for where the water is getting in. Repairs may involve adjusting the weatherstrip or the door. even the inside panel has a water pad it can be missing or partly uninstalled The windshield can be leaking, or the cowl drains are stopped up with leaves and dirt. The hose should find the problem
Nov 02, 2009 | 2003 Volkswagen Passat
Water on passenger floorboard
Iside the car,in the middle of the console is a shallow tray.Its job is to catch the codensation that drips off the aircon.Same as you see hoses coming off home aircons.this is what is in the car.There is a hose,about as thick as a finger,that drains the codensation out through the firewall of the car and into the rear of the engine bay to the ground.There may be 2 hoses.One either side if its a split catchtray.The hose has either been knocked off or is blocked.Usually blocked.The tray itself gets dirt in it and this is where 'gunk' can buildup over the drain hole.Find the hose and shoot some compressed air up the hose or run some line trimmer cord up there.Hope this helps
Sep 19, 2009 | 2000 Jeep Grand Cherokee
Water leaking into 2005 Camry 6 cyl under carpet drivers side.
I think that I can help you. It sounds like your drain-tube is plugged up. Get in the passenger side, and pull the carpet back from under the glove box. Look for a black rubber pipe that goes from a black box, and pokes thru the firewall, on the passenger side. Remove the hose from the box, and have a container ready to catch water. If water comes out of the black box, your drain hose is plugged up. Clean out the clog, and you will be golden.
Jul 27, 2009 | 2005 Toyota Corolla
Water leak passenger side in dodge caravan 2005 carpet soaked
look at the firewall on the engine side and you will see a small stub hose coming out on passenger side about even with the bottom of the heater box inside. that hose drains condensation from the ac...clear it out and you will have a dry floor. (unless heater core is leaking but you didn't mention any overheat or coolant loss so likely that's not a problem)
Jun 15, 2009 | 2003 Dodge Caravan
Water leak on the passenger rug for 2003 Corolla
well if you have water or coolant leaking on to the rug in your car, first you must remember that every car has 2 radiators. One for the Engine which is in the front of your car under the hood and one for your heater, which is usually hidden deep behind the dash inside of your car. So if you are leaking fluids on to the rug in the car; Im 90% sure its going to be something dealing with the heater radiator. What you have to do is find out where your heater radiator is on your car and check all the hoses.
Jan 05, 2009 | 2003 Toyota Corolla
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
