Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Grinding teeth on the pinion gear
I have an 95 flt. i've replaced the starter and the starter drive gear on the clutch basket. the other day it tore three teeth off the pinion gear, so i replaced it, the dealer told me maybe the engine kicked back ,while the starter was engaged and broke the teeth off that way. the other day it's back to hearing a loud crunch some times when i start it , but not all the time? is it the jack shaft???every thing looks good??
  • 116 Answers
Inner primary bearring and or the clutch hub bearring
Posted on Dec 31, 2009
GL1800 has starter that ran after engine being turned off. Smoked and only stopped after disconnect of neg batt lead. what could be the cause?
pinion gear stuck in ring gear
could be a problem ring gear I damaged teeth), problem override clutch for pinion ( incorrect teeth pitch of the starter gear)
could be a short in the solenoid wire that kept in engaged
A new starter motor will be required and the circuits and ring gear inspected/replaced
Mar 27, 2017 | Cars & Trucks
1970 Chevy El Camino starter broke teeth on flywheel. What would cause this?
several reasons
the teeth on the ring gear were damaged from continuous grinding during pinion engagement or engagement of the starter when the engine is running causing a burring of the teeth that altered the mesh ability and jammed the ring gear and pinion
metal in the teeth of the ring gear that causes a jam in rotation
starter motor not engaging before rotating
wrong no of teeth on replacement starter pinion or starter motor
Dec 17, 2016 | Chevrolet El Camino Cars & Trucks
Troy built snow blower the electric starter grinds
sounds like your starter pinion is stripped. remove your starter and inspect the gear. If the teeth are worn then replace gear if not replace starter. you will also want to check the teeth on your flywheel
Oct 07, 2014 | Garden
Flywheel or something grings against the starter when clutch is engaged
There is no way the ring gear will hit the starter pinion unless the fly wheel bolts on the crank shaft or loose allowing the flywheel to run out of true. If you have had clutch/ rear seal work done lately the fly wheel will only fit in one position and if that was ignored at some time then the fly wheel will run out and touch the starter pinion.. I would also check the adjustment on the starter pinion as it has to be set by the lever pivot to a correct distance or it will touch the teeth of the ring gear
Jul 28, 2013 | 2001 Ford Escort ZX2
How do I stop the grinding when starting 2000 Astro Van
Hello Anonymous...
To inspect the teeth on the ring gear requires the inspection to check the full 360 degrees of the ring gear. Looking past the inspection cover to examine a small portion of the ring gear may reveal no issues, but only for that section. Eventually the ring gear will end up positioned above the starter drive gear which will skip across the bad teeth creating your grinding noise when you try and start the Astro,.
Apr 26, 2017 | 2000 Chevrolet Astro
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
I want to replace the starter
take off negative cable off battery take cable off starter take 2 bolts off starter put new starter on the same way
Feb 20, 2011 | 2003 Harley Davidson FXSTD Softail Deuce
When i start my car the starter be grinding do that mean the staeter is bad?
it can do the pinion may be worn, take off the motor and see! do it now beause it might be the ring gear, you see if you ahve a bad pinion then it will dammage the fing gear! if the ring gear is dammaged... you can replace starter,, It may seem fine, but the dammaged ring will grind up the new starter's pinnion, once the ring gear is dammaged then it is gear box out! so look now to avoid more lenghty and expensive repairs!! Have a nice DAy........Bruce.
Mar 15, 2010 | 1997 Buick Park Avenue
1989 sportster braking teeth on the starter ring gear on clutch basket
chk mesh of ring and starter bendix. If teeth don't mesh right, the start will put pressure on the ring teeth improperly stressing . Teeth should pattern like a ring and pinion . Wear in center of each tooth, not on yje ends of the teeth.
Jun 09, 2009 | Harley Davidson XLH Sportster 883...
Lands Phones Logo
242 people viewed this question
Top Harley Davidson Lands Phones Experts
David Payne
David Payne
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
