Televison & Video Logo
K
KEITH MIDDLETON Posted on Apr 11, 2018
I have just bought a Humax HDR 1800T tv recorder and I am unable to receive sound I must have disabled it somehow. any suggestions please?
5 Related Answers
Anonymous
  • Posted on Feb 14, 2009
SOURCE: setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
razor_ruddoc
  • 6 Answers
  • Posted on Mar 22, 2009
SOURCE: Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
Anonymous
  • 5 Answers
  • Posted on Nov 11, 2009
SOURCE: Connection to Bose V30 System
check hdmi setting from ur tv and ur dvd connection
Anonymous
  • Posted on Nov 21, 2009
SOURCE: Humax Foxsat HDR sudden Remote Control failure..
Make sure you have pressed the "PVR" button at the top. If you have accidentally pressed on on the others TV, DVD or AUDIO then they will light up when you press another button signifying that the remote is trying to send a signal to them rather than the PVR...which is where you want it to go.
Anonymous
  • Posted on Dec 23, 2009
SOURCE: I have bought a Humax digital recorder and
What model is it? The Humax Terrestrial PVRs have two SCART outlets. If by chance you have connected the TV to the VCR SCART socket rather than the TV SCART socket then you will get the symptoms you describe. Plug the SCART into the other socket.
1helpful
How do i stop my humax foxsat-hdr recording a series when i only want one?
press to record again the same programme it will give you an option to cancel
Why does my Humax Foxsat HDR tune to stations OK sound OK but no picture just a green screen. Any suggestions?. Worked OK till about a week ago.
This is sometimes due to the PVR not communicating properly with the TV. Try turning the TV on before the Humax.
My humax freesat model hdr-1000s remote control is not working with the box
If this is brand new call the company support number ASAP. It could be something simple you're doing wrong or it could be a defective remote that needs to be replaced under warranty but you MUST call ASAP to be sure to get the problem in the records before the unit is out of warranty.
The bbc red button service on humax listing not working
You should scan for channels again, as some were changed recently.
I have a Philips 32PFL7562D t.v. connected via a Humax HDR-FOX T2 recorder. When I change back from a recorded programme to the T.V the screen goes blue then breaks up into 'hundreds and thousands. (s
How are you changing from recorded to TV? If you are switching the TV input, it could be because it's looking first for analogue TV stations but there are none any more, so it then reverts to the SCART and shows the Humax satellite station. If you are just pressing STOP on the Humax then you shouldn't have a problem, but if you do have the problem then the Humax must be faulty.
Unable to record system permanently deleting unable to access imstallation
Tell us in detail what happens when you do what. The better you describe your situation the better we can help you.
1helpful
It stops recording a few minutes before the end of the programme
Hello
A firmware update is necessary with your Humax Foxsat receiver. Get into Humax site and update the device with latest firmware. OK.
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
