2008 ford taurus X climate control system not changing functions
I have the same car and just fixed the exact same problem you just described.
It is NOT a vacuum problem. The blend door is electronically controlled my a small motor under the dash, to the right of the steering column. The clicking is coming from a stripped gear in that small motor unit.
On my Taurus X, what caused the motor to fail was the blend doors (which open and close depending on what your vent setting is on) getting stuck. That caused the motor gears to strip out and make a clicking sound every time the automatic climate control tried to move the blend doors.
The fix required a substantial amount of the dashboard to be taken apart. The blend doors were re adjusted and the motor control unit replaced.
I had the Ford dealership do the repair and it cost me $450. (Ouch!)
To make sure that's your problem, you can follow the clicking sound. You'll have to get on your back and look under the dash on the drivers side. Have somebody press the defrost button to cause the clicking sound. Once you find the small unit you can actually feel the gears slipping when it makes the clicking sound. It's really tight under there though and you'll probably need a flashlight.
