Question about Denon AVR-1707 Receiver
Denon AVR 1707: Optical input reading as analog instead of digital.
5 Suggested Answers
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
SOURCE: Analog output from digital input for Denon AVR 3803
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Posted on Apr 29, 2009
mlapres
  • 757 Answers
SOURCE: No audio on Denon AVR-588 from digital sources
If it is set to automatically detect connections then by default it will send signal to the one with the highest bandwidth, much like back in the day when you might have S video and composite connected simultaneously to the same input. So if you have your HDMI input assigned to DVD it will output that over optical or coaxial.
Posted on Jun 18, 2009
SOURCE: My Denon AVR-5800's optical (toslink) inputs no
everything is HDMI connection now. i still have the avr-5800 denon reciever. how can i make this work with my new LCD, DVD with hdmi connectors now a days. i want to keep my AVR but this lucks of hdmi connection. so how can i make my connections on these? video and sound?
Posted on Dec 07, 2009
I cant connect my Denon avr 682 to my pc via optical??
I would change your setting on your receiver to digital. its probably on analog. look for a button that says that. You might have to change your input have a look at the rear and see if it says, DVD optical or CD and choose that input.
Dec 09, 2012 | Denon AVR-682 Receiver
Trying to hook my lg tv to a denon avr-1707 receiver so i can have external speakers
Use the twin phono audio out on tv to twin phono audio in on Denon AVR-1707 this should work absolutely fine as long as your using an analogue input on the tv if HDMI you would need to purchase a Digitial to analogue audio converter. Hope this helps
Jan 31, 2011 | Denon AVR-1707 Receiver
Denon AVR-682 center channel has no output
You may have had the receiver set to "Stereo" mode, or Analog instead of "Digital" or "Auto" (automatically switches to digital when it detects a signal) modes. Also, setting it to "Direct" (2-channel from an analog source) could result in loss of center channel. Or your Surround Parameter dial (on the higher-end Denons, at least) could be set to a 2-channel mode.
Finally, if your digital inputs are incorrectly assigned (e.g., COAX1 instead of OPT1, or OPT2 instead of OPT1) for that source, the receiver will use the Analog signal which is stereo-only. You could get a center channel via Dolby Pro Logic II but it would be a "matrixed" signal, not the "real" center channel you could get via digital input using Dolby Digital or DTS.
(If all else fails, re-check your center channel speaker wire connections. It's very unlikely, but also possible, that either the receiver center channel amp or the speaker has failed.)
Feb 13, 2010 | Denon AVR-682 Receiver
I have a Denon 2800 hooked up to a Pioneer DV-C302D and while DVD's thru the Denon, the sound will come on and off. At the same time the Denon will be switching between analog and digital mode. Is one of...
It's a cable or connection.
The Denon apparently has an automatic selector to choose the digital input over the analog input if both are present (my Pioneer does this). The random switching is telling you the digital input is intermittently dropping out and coming back. You don't say if you're using the optical or coaxial digital interface. Coaxial is less prone to connection problems. If you use optical, make sure the ends are clicked in and there are no small radius bends in the cable. Tight curves reduce the optical power. Either way, check the connections and wiggle them to see if you can cause the problem to return.
Jan 18, 2010 | Denon AVR-2800 Receiver
What is the best way to attach a Sony SCD CE595 CD player SACD to a Denon AVR 2105 Receiver. I thought the optical input would be best but according to a web posting, toslink does not support SACD
That is correct. Digital connections through some models of SACD players are via "firewire", otherwise it is analog output. There are no optical connections.
The shortest pair of RCA cables, or even component video cable as an alternative will work.
Dec 12, 2009 | Denon AVR-2105 Receiver
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
Jul 22, 2009 | Denon AVR-3300 Receiver
Hope this helps.
Matt
Dec 20, 2008 | Denon AVR-3803 Receiver
Denon AVR-1707 Receiver Logo
185 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
