My TS-H552 will not recognize any CD-R to play or write to.
My rewritable will not recognize any CD-R or write to one. But will recognize a DVD-R and DVD-RW
  • Chris  Morse
    Chris Morse May 11, 2010
    What programs are you using to burn cds?
  • 123 Answers
Have you tried a CD/RW? let me know.
Thx
Posted on Aug 01, 2009
My cd/dvdw Ts-H652L optical drive recognizes and plays cd's but not dvd's.
Hello
The laser pickup unit of the DVD player may either be dusty or dirty. Try to clean it, by inserting a lens cleaning disc into the player and play it until it pays completley. Then check it out.
If this do not help you, the laser pickup unit is faulty. It will be best to muy a new Player, rather than try to repair it, especially to computer DVD players. OK.
Feb 02, 2012 | HP Compaq Presario SR2020NX PC Desktop
Driver neede
Try driversguide.com or drivershq.com
hope this helps
Apr 08, 2011 | Samsung TS-H552 (810884008760) Burner
My system not detect dvd+r/rw ts-h552 drive
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
My DVD/CDW-ROM drive is gone! It is a TSSTcorp TS-H552D How can I down load a new driver free?
Try the following link;
http://support.microsoft.com/mats/cd_dvd_drive_problems/en-us
If that doesn't work I suggest you install a free program called "Slim Drivers" and allow it to scan your system and locate the correct driver. I recommend noting which drivers you're installing so they can be rolled back should one of them not function properly.
http://download.cnet.com/SlimDrivers/3000-18513_4-75279940.html
Feb 19, 2011 | Gateway GT5408 PC Desktop
How do i set my TS-H552 as slave?
Look closely at the "back" of the unit.
Look for a 2-by-4 grid of pins, labelled:
* MA(ster)
* SL(ave)
* C(able)S(elect)
* SP(are)
Move the small "jumper" to the 'SL' position.
Aug 02, 2010 | Samsung TS-H552 (810884008760) Burner
Device reads cd but will not recognize a dvd
you may need the codec pack from
www.freecodecs.com
to play dvds. if you are running windows xp then it does not come with the codecs for playing dvds.
download the xp codec pack, run the installer and away you go.
Sep 26, 2009 | HP TS-H353B/HPBH Internal DVD Drive
I have a cd/dvd rom that will not recognize
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Sep 01, 2009 | Samsung TS-H492A (TS-H492A/WBGH)...
Pc will not recognise burner
Try this, click "Start" "Run" type in "regedit" click ok, in the left field click on the "+" next to "Hkey_Local_Machine" + next to "System" + next to "CurrantControlSet" + next to "Control" + next to "Class" then click on " {4D36E965-E325-11CE-BFC1-08002BE10318} " then in the right field click on "Upper Filters" click "Delete" now right click on "Lower Filters" click "Delete" restart pc. Hope this works for you, gl
Jun 22, 2009 | Samsung TS-H552 (810884008760) Burner
Cd burning problems
hello sir..i have a solution to your CD burning problem...sometimes if you are not regularly using your CD-RW drive then there are chances of CD-RW lense prob,so please do clean the lense using lense cleaner CD available in the market,even then if you not able to burb the CD then please do reinstall the software which you are using for CD burning...i suggest you NERO software for CD burning which is a user friendly software...
Oct 30, 2008 | QPS Que! Fire CD-RW Burner
HP 640a cd/dvd burner
methinks you have a major device issue. Check it through control panel, hardware devices to see if driver is happy or not/
Feb 18, 2008 | HP Pavilion a1240n (EG136AA) PC Desktop
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
