Question about Maytag Neptune MAH6500A Front Load Washer
Control buttons are getting no power
Working fine...went back to use it and no power is getting to the control buttons that operate the machine. Please help ! What can I do ?
  • NednDot Nov 25, 2007
    I have the same thing happening to our Neptune Washer. Power to the machine (inside light comes on when door opened) but the control panel is completely dead---no lights on whatsoever. Worked yesterday just fine. Today when I went to use it, it's dead!
  • 249 Answers
Check for power at door switch
Posted on Nov 25, 2007
PANASONIC CS-CU E24PKR fault code H00
H00 No abnormality detected - Normal operation
You may have a problem with the outdoor controller, the indoor controller or both. Power outages can do some strange things to the electronics. Turn the A/C isolator off for five minutes and back on again to be sure the problem is still there. You could also try this:
• To clear memorized error (Protective operation) status
after repair:
1. Turn power on.
2. Press the AUTO button for 5 seconds (A beep
receiving sound) on the main unit to operate the unit
at Forced Cooling Operation mode.
3. Press the CHECK button on the remote controller for
about 1 second with a pointed object to transmit
signal to main unit. A beep sound is heard from main
unit and the data is cleared.
Jan 31, 2015 | Panasonic Heating & Cooling
The on and off switch wont turn on
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace control
May 23, 2013 | Hotpoint Washing Machines
Nothing works on control panel except control locked sensor light. The buttons were working fine then I went to add more drying time and the buttons do not light up or work.
From the details of your symptom you're indicating a possible intermittent loose connection between the user interface (touch panel) and the machine control board or the voltage supply to machine control board at P1 connector.
Disconnect the power cord from the power source.
  • Disconnect P3 and P4 connectors from the machine control board and then reconnect them.
  • Disconnect P1 connector and then reinstall the P1 connector and then recheck operation.
If the wires are good then you will need to replace the control board on your unit.
Here is a link to the part.
Jan 09, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Power button beeps three times. Lock button works. Nothing else works.Technician diagnosed microcomputer control board. Replaced board control 8183258. Still dead!- he never called
Try to unplug power cord for 10 minutes and plug in. If you have manual on hand, follow instruction to find error code on your machine. Please tell problems before it went dead. Thanks.
Aug 10, 2010 | Whirlpool GHW9200L Front Load Washer
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
May 30, 2009 | Vizio GV47LF Television
check your power board, most likely that's the part that is causing the problem.
Feb 09, 2009 | Vizio GV47LF Television
Kenmore het3 washer just quit, no power.
If power to the unit then most likely the machine control went bad and would need to be replaced. There are no fuses or reset buttons. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Washing Machines
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Random electrical problems, sometimes it works beautifully, sometimes not!
F11 = Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Le code d’erreur “Verrouillage porte” apparaît s’il n’est pas possible de verrouiller la
porte. Le système effectue six tentatives de verrouillage avant d’afficher le code d’erreur.
■ Door lock mechanism is broken or removed from door.
■ Door switch/lock unit failure.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Locked up. Hard drive frozen?
i have the same frickin problem.someone please help
Dec 29, 2007 | Fostex MR16HD/CD Digital Recorder
Maytag Neptune MAH6500A Front Load Washer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
