Question about Sony Playstation 3 (PS3) Console
Green Screen Hello!  Just hooked up via HDMI a brand new PS3 to a month-old Sony Bravia HDTV.  Went through the set up screens, then it downloaded updates, then it displayed a blank, green screen and nothing else will happen.  Re-booted it to no avail.  Also turned TV off and on.  Any ideas?
Re: Green Screen
Hey guys i just but my ps3 console , am trying to upgrade te firmware he just go blank . i can;t return it back to the store .wat can i do ? to make it works , pls reply me to my email
Posted on Dec 19, 2007
0 characters
3 Points
I have both an HDTV and a regular tv. When I set up the ps3, I told it to hook up with the HDMI cable. I want to move the ps3 to the regular tv, and the video and audio won't appear on my regular tv.
First add the basic wires to the old tv too. Then go to the screen options while using the hdmi on your hdtv and set it to the normal non-hd screen mode. Then it should appear on your regular tv
Feb 21, 2010 | Sony Video Game Consoles
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
Went from HMDI to standard cables=no picture and no sound
reset your settings on the ps3 on your old tv using the same set up then go to the new tv and it will come on. I had the same prob
Apr 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 Video Connection--Lines on TV
this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 no picture on screen. Borrowed Unit from a friend.
If the TV was originally set up on an HDTV via HDMI cables you'll have to reset the video/audio outputs on the PS3. When you turn the PS3 on hold your finger down on the button until it beeps a second time, then remove your finger and let the console restart. That should reset the PS3's video output.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Ps3 won't display on hdtv via dvi
Re-Set the PS-3, by pressing and holding down the power button (front panel) this hard re-sets the unit and yo can then reconfigure via the composite video cable it came with, back to HDMI / DVI
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Ps3 unit stopped working
when on standby hold the power button for 4 seconds, it runs the optimal settings screen, i dont think this is your prob but it might help. What cable was used at your neighbours? was it an hdmi cable? did you knock your ps3 when moving it?
Feb 13, 2008 | Sony Playstation 3 (PS3) Console
HDMI into sony bravia
plug in hdmi cable turn ps3 off then on wait and a message will apera click yes then another message appers then click yes then it should work if not connect with the red white yellow plug and then change the settings to hdmi and plug the hdmi cable in
Sep 06, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
815 people viewed this question
Top Sony Video Game Consoles Experts
Troy Gorman
Troy Gorman
Are you a Sony Video Game Console Expert? Answer questions, earn points and help others
