Question about Dishwashers
Bosch dishwasher Start Process
I recently purchased a Bosch dishwasher - SHE45M02UC/53. The only complaint I have is the proceedure required to start the dishwahser. The proceedure is as follows:
1. First I have to turn the power off
2. Next, turn the power on. Immediately the dishwasher start running. I can change the settings at this time.
3. Once the dishwasher completes it's cycle none of the front panel buttons work....until you turn the power off - and you are back at the first step above.
Bosch customer services says this is normal, but seems crazy to me.
Is this correct.
  • 123 Answers
Lol...yes this is normal for a Bosch. They have several "safety" measures incorporated into their dishwashers. Look on the bright side they are one of the very best dishwashers on the market and are known for their longevity and quietness.
Posted on Aug 01, 2009
  • Kenneth Reaume' Aug 01, 2009
    lol...yes this is normal for a Bosch. They have several "safety" measures incorporated into their dishwashers. Look on the bright side they are one of the very best dishwashers on the market and are known for their longevity and quietness.
How do I reprogram the start, rinse cycles? snowflake is blinking and nothing happens when I try to start washing.
[PDF]Download Bosch Dishwasher-Manual - DASH Property ...
www.dashpropertymanagement.com/.../Bosch-Dishwasher-Manual.pdf
Lift tab to open the rinse aid reservoir and add -3 tablespoon max, do not overfill. "qUid rinse aid ... Cancelling a cycle I Reset the dishwasher. 0 LEDs flashing ...
[PDF]Dishwasher Use & Care Guide EIDW6105G - Datatail
media.datatail.com/docs/manual/40243_en.pdf
We view your purchase as the beginning of a relationship. ... Store dishwasherdetergent and rinse agents .... This cycle allows you to program your preferred.
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
https://www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR
KITCHENAID DISHWASHER REBOOT ... Dishwasher Repair will not start - Repair & Diagnostc - Kitchenaid - Whirlpool ... What toDo When the Dishwasher Won't Start - Duration: 5:43. by doityourselfstan 217,315 views. 5:43 ... KitchenAid & WhirlpoolDishwasher - Not Cleaning ,pump wash arm impeller ...
Dec 16, 2015 | Dishwashers
Bosh diswasher SHE45M02UC/48 doesnt stop when I open the door
That is the drain pump that is running, and it indicates that there is water in the base of the unit. You will need to unplug the dishwasher and pull it out. You can tip it forward to drain the water out of the bottom through the holes in front. Have some towels ready to catch the water. Now if you plug the dishwasher back in, the pump should not run But now comes the hard part - figuring out where the leak is coming from and fixing it. It could be from a hose, the drain pump, or the main pump. Bosch dishwashers are notoriously hard to work on, so I recommend calling in a professional DW repairman.
Feb 25, 2015 | Dishwashers
I have a Bosch automatic dishwasher,SHU43C05UC/17. Usually I love it; but recently my glasses are coming out cloudy and the tea stain remains on my cups. I have used two different dishwasher cleaners...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Jan 19, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Have a Bosch dishwasher, about 10 years old works ...
Check the hinges in the sides. may be requires little lubrication. Use an appropriate lube spray available in your shopping area.
May 21, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Error message E06. Will not start . Bosch Excell dishwasher. Only 6 days old
This error code is the door mechanism or the electronic panel. Mine also had it within days of purchase, got fixed. Seems to have shown up again.
Dec 28, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch dishwasher srs45e02. when I turn it on there is a loud growling noise for a while then it turns itself off. any ideas please. I think it could be the pump. thanks any help.
you could be correct as the proceedure for all dishwashers when started is a pumping phase to make sure no excess water is still in unit.. when finished water then flows in..
Dec 17, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
I am a builder. I installed my Bosch dishwasher.
Hello Gerry, There are two (2) ways to accomplish this. The easiest is to get some RV anti-freeze (enviromentally safe version) and put that into the bottom of the dishwasher as per the instructions. Then when you return in the Spring, just run an empty rinse cycle to purge the dishwasher of the anti-freeze solution.
The other method will require you to remove (pull out from under the cabinet) the dishwasher and (with power turned off!) disconnect the sump pump boot to drain the residual water out of the unit. In some models, there is a small drain plug that you can remove to drain the water out of the bottom sump (pump) section of the dishwasher.
Good that you thought of this, as many folks forget that leaving water in their appliances in freezing conditions can cause some major headaches from burst pipes, pumps, etc. if they aren't properly winterized for the freezing temperatures they'll get in an unheated building.
Hope you find this Very Helpful and best regards!
Nov 17, 2009 | Bosch Dishwashers
Bosch SHE43MO2UC/48 - Dishes do not dry properly
rinse aid is required to aid the drying process either it is underdosing or the wash programme is too short temps over 55 degrees are needed for satisfactory drying result.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SHU43C02UC
Unplug from mains for 5-10mins. Are you having any power difficultys? sometimes this can crash the controller.
if none of the above possible that its the controller
Jan 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
260 people viewed this question
Top Dishwashers Experts
