Question about Averatec 3200 Notebook
My wieless card shuts down after 5-10 minutes.
My wrieless card shuts down after 5-10 minutes. Have to cycle the on/off switch to get it back online. Had problem awhile back and forgot what the fix is. Think it involved turning off an automatic function of some kind for the wireless card..
  • 61 Answers
Go to control panel and check your power settings. it is possible that it is set to some sort of power save mode. Try changing those settings especially if you see something related to the wireless card. It may have settings to increase the time before it shuts off or even to set it to never shut off.
Posted on Aug 11, 2009
Dishwasher malfunction
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board.
Jul 08, 2013 | Dishwashers
Our Kenmore dishwasher model number 665.13163K701 display is always showing the heater cycle indicator on. Tried some reset instructions I found online and turned off breaker for a few minutes and still...
please follow the next steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. 87af5b68-272e-404a-951c-cd453d3cd7fe.jpg
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic control
Jul 06, 2013 | Dishwashers
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
Mx4000 128mb on xpsp3 problem
in windows power settings, you ajust the time the monitor runs and shuts down one setting is do you want the monitor to stop after 5,10 or so mins you answer never that will cure the shut down
Jul 06, 2010 | XFX GeForce MX4000, (64 MB) Graphic Card
My Bryant Quantum Plus with Puron Air Conditioner is two years old at max used for one season. The fan spins and then I hear a click and it shuts down for a minute clicks back on the fan spins for a minute...
the outside unit is cycleing on a low pressure switch you need to call for service you have a leak and the system needs to be recharged afte the leak has been fixed
Jun 16, 2010 | Heating & Cooling
Kenmore 110 washing machine thermally cycles
Does it operate properly if you or something holds the switch down? If yes, then extend the end of the lid switch with hot glue, epoxy, or silicon glue to allow the switch to be pressed sown further. You can also build up the contact area under the lid if you choose--same result.
Aug 07, 2009 | Washing Machines
Cannot turn on the wieless network device for toshiba A70
There is a switch on the side of your laptop with enables and disables the wireless card in your laptop. Make sure it is on and lit.
Mar 04, 2009 | Toshiba A70-S256 Notebook
Dryer shuts down in the middle of the cycle before the timer goes off. if you try to restart it will not. wait 15 minutes or so and it starts right back up and finishes drying the load.
Probably the motor is getting too hot and the thermal overload switch is shutting it down.Usually means bad motor or dirty motor. You'll have to take it apart to see. Model # and Brand would help.
Mar 27, 2008 | Dryers
Averatec 3200 Notebook Logo
67 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
