Question about Refrigerators
We have a Kenmore Coldspot fridge that is not very old (4 or 5 years). It is collecting ice in the top middle section that drips water down into the refrigerator. A repair person came and took a blow dryer to dry off whatever the element is back there. He did not replace any parts. We paid him $95 to come to the house. There is no ice in the freezer (we keep it ice-free). Now that it is hot outside, it's doing it again. Do we need a part? thanks, Ruthie
  • ristich54 Aug 01, 2009
    Is the panel that needs removing on the exterior part of the refrigerator? It would be helpful to be more specific. Thanks. I cannot rate your solution properly until I do the thing you're suggesting, right? right.
  • Refrigerators Master
  • 1,606 Answers
You need about a 9 inch piece of aluminum wire (14-16 guage) about $1.00 from home depot or any hardware store . Remove the rear freezer panel and defrost the drain with a hair dryer . After defrosted , pour a little hot water down the drain to make sure it is clear . Also , use a small hose inserted into the drain hole and blow , to remove any particle blockage . Insert the wire into the drain , using NO force , and wrap the other end of the wire about 1 turn around the calrod heater , to transfer heat into the hole when in the defrost cycle . This will keep the drain clear of ice and let the water go into the drain instead of the refrigerator .
Posted on Aug 01, 2009
  • Mike Smith
    Mike Smith Aug 01, 2009
    Inside the freezer section where you keep the food .
  • Mike Smith
    Be sure to strip the insulation completely from the wire you use .
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I have a Kenmore coldspot top freezer, model # 106.70162990. it drips A LOT of water from the center to back in the top of the fridge, so much that it collects in the veggie and fruit bins and under...
Make sure the fridg. is level,(if it has been moved recently) there is a tube that allows the water from the evap. coils when defrosted to run to a drip pan. The tube is either frozen closed from prior defrosting or something is blocking the tube just below where it is leaking at. Turn fridg off and leave freezer door open (with a fan blowing in freezer if possible) for at least one hour and return to regular operation.
Aug 16, 2010 | Kenmore Refrigerators
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Water collecting in bottom of freezer
Your seal may be bad letting in moist air that provides a source of water to condense on parts of the freezer.
Jul 24, 2010 | Kenmore 53703 / 53706 Stainless Steel Side...
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fresh food section not maintaining cold temp
You're frozen up.  Defrost completely.  Then, clean your condenser.  Make sure to never leave open containers in the fridge...water condenses into ice.  If you still have problems, you may be low on gas.
Nov 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
ICE MAKER NOT WORKING Kenmore cold Spot model# 106.55536400
there is some times a water relay that turns the water on and off the over heats, it located in the back where the water connects
Dec 08, 2007 | Refrigerators
Water dripping from top of fridge (coil housing?) under freezer.
I HAD LEFT THE DOOR AJAR ON MY KENMORE DPOUBLE DOOR WITH TOP FREEZER AND IT FROZE UP NOT ALLOWING THE WATER FROM THE NORMAL AUTOMATIC DEFROSTING PROCESS TO GO DOWN THROUGH ITS NORMAL DRAIN. THE ACCUMULATED WATER THEN DRIPPED INTO THE REFRIGERATOR UNDER THE FREEZER AND HAD TO BE SOAKED UP DAILY. THE SOLUTION--I REMOVED THE ADJUSTABLE
THATBOTTOM PLATE HAD AN UPWARD CURVED PORTION AT THE REAR. WHEN RE-MOVED, YOU COULD SEE FROZEN ICE ACROSS THE BACK UNDER THE VERTICAL COVER THAT COVERS COILS(?).
IN THE FAR BACK BOTTOM THERE WAS A FULL LENGTH, APPROX 1 1/2" WIDE DRAIN AREA WITH A HOLE IN THE CENTER THAT WAS PLUGGED WITH ICE.THAT WAS PREVENTING THE NORMAL DRAINING PROCESS.
A HAIR DRYER AND ABOUT 15 MINUTES MELTED THE PLUG, I THEN POURED A GLASS OF HOT WATER INTO THE HOLE AND IT DRAINED RIGHT DOWN LIKE IT SHOULD.
I HAD THE SAME FREEZE UP & DRIPPING PROBLEM A COUPLE YEARS AGO AND IT COST ME $100 FOR A SERVICE MAN TO FIX IT BUT IT'S REALLY A SIMPLE PROCESS TO FIX.
Sep 11, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
