Question about Watches
I am trying to set the time on my speedo watch refl4? Can anyone help??
How to set up watch with time date and alarm modes
Right side lever hs different levels , you pull it and each level hs different functoionality , it might be clockwise or counter clockwise. try rotating both sides for each levels
Jan 09, 2014 | Santai Watches
I have a new windy watch but dont know how to set the date and time on it could anyone please help me?????
annoyingmist, let me try.
1.by windy you mean mechanical?
2. if yes, then move the hands clockwise watching the calender until new date appears.
3. now turn hands anti- clockwise a little and clockwise again. Keep doing until you get today;s date.
4. set the watch to correct time. good luck.
Dec 25, 2013 | Watches
I have the Speedo Kids Active Swim Watch and cannot remember how to turn on/off the alarm and set the alarm. Please help!
You might find this pdf helpful - it gives a basic description of how 4 button watches can be set.
www.buydakotawatches.com/PDF_FILES/Digital.pdf
Sep 10, 2010 | Watches
Anyone know how to set time on a NY-1385 watch?
First, go to the time mode which displays week day, seconds and timeas opposed to calendar, seconds and time. To do so, touch and hold upper left sensor until the watch beeps. Then use the upper right button to switch to the proper time mode. Then touch and hold lower right sensor. This will send the watch into settings mode.
May 03, 2010 | Watches
Citzen eco drive watch stopped when i changed time
Try to find solution here:
http://www.citizenwatch.com/COA/English/settings.asp
Interactive settings are very helpfull as well.
Rate, please.
Mar 30, 2009 | Citizen Watches
Can't get kids gap watch move from military "24" hr time!
hit mode three times until TUES flashes and the seconds. Hit reset until the hours flash and hit start to change them. The watch goes from AM hours to PM and then back through AM and when it cycles through the PMs for the second time, they will alternate 12/24 hour time.
Dec 22, 2008 | Nike Triax Fly WK0006 009 Watch
Setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Oct 16, 2008 | Watches
Sector adv 1000 setting alarm
key for setting time can be pulled fully (to set time) or shortly (only 0.5-1 mm) for setting alarm. then you should turn it and watch how it moves (automatic, without your turning). when it comes to desired time just push key in. the watch will automatically rewind to present time and it will re-start running.
Apr 14, 2008 | Watches
Columbia Watch CL-5030
Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
Dec 25, 2007 | Columbia All Sport Digital watch
Watches Logo
248 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
