Question about Garden
Primmer bulb leaks. Where can I get a new one. Mine is a Homelite string trimmer model ut-21506.
    President:
  • 1,776 Answers
I would try your local hardware stores, stores that sell mowers and trimmers, or even a store like tractor supply. There are numerous places that sell replacement primer bulbs. Just remove the old one and take it with you for comparison purposes and I am sure you can find one in your local area. ( I got mine at ACE Hardware, for example) Hope this helped and best wishes.
Posted on Jul 31, 2009
ST200 trimmer. What kind of spark plug to get and what size string does it take?
Hi Cherri,
I think this is the manual for your machine. It should tell you all you need to know:
file:///C:/Users/Jim/Downloads/Homelite-String-Trimmer-Parts-Manual-ST200-String-Trimmer-UT-20501-A.pdf
Good Luck!
Jim
Sep 02, 2015 | Homelite Garden
Homelite y 2500 yardmachine trimmer
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
May 22, 2014 | Homelite Garden
Internal line in gas tank came loose
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
Jan 23, 2012 | Homelite Mighty Lite Lawn Trimmer
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
Jan 09, 2012 | Garden
I have a homelite string trimmer,I bought new fuel hose for it.the fule lines on it rotted! I'm confused ! the one that holds the filter ,where does it connect to? Thanks Bob
If the primer is on the carburetor the filter went to the primmer the suction and the other line from the primer went back in to the fuel tank.
Mar 20, 2011 | Homelite Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
MY HOMELITE STRING TRIMMER UT21505 PRIMER BULB LEAKS. MY PARTS LIST DOE'S NOT SHOW THIS PART. CAN I PUCHASE IT OR DO I HAVE TO THROW IT AWAY
You can easily get a new primer bulb for it...most small engine repair shops will have what you need, and if you want, you can most likely snag one on Ebay....DON'T THROW IT AWAY, ok?
Jul 10, 2010 | Homelite Mighty Lite Lawn Trimmer
Bgreen. Need correct part no. for primer bulb for sx135 bandit string trimmer. old one has cracked due to age.
Your SX-135 string trimmer was built by Homeliteand has a model number of UT-20601. That said, your trimmer's primer bulb part number depends on teh type of carburetor it has. If your trimmer has a Walbro carburetor, the primer bulb part no. is 01201. If it has a Zama carburetor (the most likely one) the primer bulb part no. is A01195A.
You can go to the following website to order the part: http://www.homelite.com/service_support/order_parts
Good Luck, hope this helps!
Oct 15, 2009 | Garden
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
