Question about Kenmore 96222 / 96224 / 96229 Electric Kitchen Range
Oven won't reach set temperature
Just replaced the sensor per SolutionGuy's advice. Unfortunately this did not solve the problem. Despite setting the oven to, say, 425, it only preheats to 350 - almost like it is ignoring my temp setting and defaulting to the 350 initial setting.
  • 456 Answers
SOURCE: Oven won't heat accurately
The main problem is the manufacturer's fault in the setting accuracy of the temperature, i mean when the manufacturer has to adjust the temperature into the required temp it does not set to the required one. This is called "calibration" in engineering, the best for you is to tell the manufacturer to replace or keep it.
Posted on Nov 30, 2007
  • 2651 Answers
SOURCE: low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Posted on Oct 21, 2008
SOURCE: hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Posted on Nov 05, 2008
  • 242 Answers
SOURCE: Oven won't reach proper temperature and hold
If the element glows its ok , if you have replaced the sensor with a new one it can only be the control board. in some cases you can adjust the temp. through the control , it should list directions to do so in the manual. Good luck
Posted on Dec 30, 2008
  • 21 Answers
SOURCE: Oven not about 100 deg. below temperature setting
It's easier to eliminate the element.You can do this two ways;first thing,remove power from unit.Unplug it and you know for sure power is off.Inside the oven you can get to the wiring on element by removing the two screws on the back wall that holds the bracket to the wall.(this works for both elements)Pull the element out and you will see the wires(2).They will be either screwed on or connected with spade clips which pull on/off.Remove at least one wire and use your meter,set on ohms, put a meter lead on each element connector,you should read continuity.If you don't the element is bad,replace it.Give the elements a good visual inspection first,some times you can see where the element burnt out.The other way to get to the wiring by pulling the back panel off the stove.Hope this helps. Gregg
Posted on May 29, 2009
  • 999 Answers
SOURCE: Oven continues to heat after reaching set temperature
It's held in place by 2 screws in the oven. Take out the screws and pull the wire gently. It has a connector on it but if it comes unplugged or the wire breaks inside a simple fix just got complicated. God luck.
Posted on Sep 18, 2009
0 characters
1 Points
Why doesn't it heat to set temperature?
Hello. In most ovens with an electronic control, the temperature is regulated by 2 things--the sensor and the oven control board. The sensor is simply an electrically resistive device that changes resistance as the temperature increases or decreases. It is connected to the main control board by 2 wires(just a "pigtail") and the main board is supposed to be calibrated to adjust properly. Most control boards have a built-in program by which you can adjust the calibration +/- 35 degrees. If your oven is outside that range, and you're sure that the sensor is good, the connections are good, etc., then the oven control board temp control circuit has gone bad. Keep in mind, when you turn on an electronically controlled oven, the first time it heats up is USUALLY hotter by about 50 degrees--this allows the floor, walls, and ceiling to reach proper temperature. This is called the initial spike. In gas ovens, the user must wait approximately 8-10 minutes AFTER the oven beeps to cook anything. In an exposed-element electric oven, the user waits approximately 10-15 minutes after the beep. In the hidden bake element models, waiting 20-25 minutes after the beep is normal!
Also, keep in mind, ovens can have 60 degree temp swings higher and lower(as long as the midpoint is close to the chosen temp) I hope I've helped you!
Sep 15, 2015 | Kitchen Ranges
Brad, your right on track. But I'd look toward the sensor first (The computer only does what the sensor tells it to do). I'll need the model number to find part numbers to help you further. The model number is on a sticker located on the oven body behind the lower drawer. It'll start with 3 digits then a decimal point the more digits (xxx.xxxxxxxx).
Sep 27, 2007 | Kenmore 96222 / 96224 / 96229 Electric...
Replaced the ignitor on XL44, glows, lights, but turns off way before reaching temperature. I've replaced sensor as well. ideas?
Number 43 is the part I suspect is bad on your stove. It is the oven sensor. It relays back electrical current to the electronic range control. All stove sensors are built the same. They should test out @ around 1100 ohms @ room temp. If the sensor is off it will not relay correct readings to the control.
Nov 08, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
Oven heat is occassionally at different temperatures eventhough display is set. Same items with same set temperature can take upto 30-45 minutes longer than normal. Ocassionally, getting F2 error and...
Hello & Welcome to FixYa
F2 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Jan 06, 2011 | GE JBS55 stainless steel Electric Kitchen...
Oven fails to reach correct operating temperature. Set at 400 = actual 300 temp. Temp probe is clean.
Clean and working correctly are 2 different things.
Unplug the range. Remove the temp sensor. Use a meter set for ohms and read 1050 to 1150 ohms at room temperature.
If it reads OK replace the electronic control. If it reads bad replace the temp sensor.
Jan 04, 2010 | GE Kitchen Ranges
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I read my wonderful "user's guide". In the section, Controls at a Glance, I found OVEN TEMPERATURE ADJUSTMENT OPTION & followed 5 easy sets. It worked!!!
Nov 11, 2008 | Maytag MGS5870 Gas Kitchen Range
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 96222 / 96224 / 96229 Electric Kitchen Range Logo
21 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
