Question about Goodman CLQ36AR49 Air Conditioner
Cooling down the townhouse slowly???
Just turned the a/c (goodman) on this morning. it has been on approximately 8 hours and has only dropped from 89 degrees to 85 degrees.
  • FNGHVAC May 11, 2010
    Need more info. Is outside unit running? Indoor fan blowing? What's the temp. outside? What's the thermostat set at. When you check the outdoor unit make sure not only the fan is running on top, but the compressor is inside. You may need to turn it off at the disconnect and then back on to listen for the compressor start up.
    Scholar:
  • 76 Answers
Hot hot is it outside? is this a new system or somewhat older system? Do you know the S.E.E.R rating on the outside unit? Do you have any refrigeration gauges? CHeck outside and feel the bigger of the copper lines thats coming through the house. Does it feel warm? is it iced up? Does it feel somewhat cold? There can be several things. If its really hot outside then its probably not keeping up with the heatload inside the house. You can be low on Refrigerent charge. Evaporatore coils can be plugged and iced up.
Posted on Aug 01, 2009
    President:
  • 704 Answers
It could be that the A/C has a slow leak from sitting without use (usually over the winter months) and you've lost some freon and the unit requires a recharge.
Another thing to check, but shouldn't really be causing this problem, unless really blocked is to make sure is to put in a new air filter. You need to change them every 2-3 months if using the better quality pleated ones during the heating and A/C seasons.
I'm betting on the A/C needing a charge of freon to get things cooling better. Unfortunatley, this will require a certified A/C tech, since you have to be trained and licensed to perform this type of service. (unless you have the recharging gauges and some freon available to you and know how to get the right amount into the unit.
Hope this helps, best regards!
Posted on Jul 31, 2009
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
Goodman gph1348m41ac unit is blowing cool air in heat mode with mid 30s ambient outdoor temp. I turn it off then on and will usually blow warm air but this cycle is becoming more repetitive. any expert...
A heat pump on the optimal heating day (about 50 degrees ambient) will only deliver approximately 85 degree air as compared to 125 degree air from a fossil fueled furnace. The colder the outdoor air is the less heat there is available to be transferred to the living space. At 30 degrees, the heat transfer capability is getting close to negligible meaning the run cycles will be approaching continuous and eventually as the heat pump along cannot maintain setpoint, the outdoor stat or stats will bring on auxilliary heat in the air handler.
If your ambient temp is below the 'balance point' of the heat pump, the house temp will drop a little lower and most times energize the heat strips through the outdoor t-stat. Your outdoor stat could be set too low for the heat pump to carry the structure all the way down to the balance point so when you turn it off and back on, the lower indoor temp automatically brings on the heat pump plus a heat strip or two, thus the warmer air. Second stage on the stat satisfies due to the heat strip, drops them out of the circuit and the heat pump is left running on first stage heat delivering the perceived cold air.
Your outdoor stat could also be not functioning correctly and not allowing the heaters to come on until the system is turned back on reestablishing the two stage call for heat.
Tons of possibilities and not enough room to list....
Jan 01, 2015 | Goodman Manufacturing Goodman GPH1348M41 4...
My frigidaire freezer is set at 4 farenheit, frequently it changes by itself to -8 ????? have to remove ice or check goods inside
Hello Carlos Rojas, thank you for your post!
I understand that your Frigidaire refrigerator has been having some cooling issues. It sounds like a potential issue with your control panel or thermostat. I recommend performing a reset on your refrigerator which you can do by disconnecting the power cord for roughly ten minutes. If that does not help correct the issue I would advise to seek assistance from a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 11, 2014 | Frigidaire Refrigerators
I have a Goodman CKL24-1k air conditioner. I live in a townhouse in Louisiana on the 2nd and 3rd floors. I set the temperature to about 73 degrees during the day so I can sleep bc I work the graveyard...
I lost you at my the end but the 2 ton unit should be able to cool 960 sqft. Sounds like a refrigerant problem. Air conditioners should cool the air 15 to 20 degrees. This means 80 degrees going into the machine in the return should be 60 to 65 degrees coming out in the supply. If you are in that range than it's likely never going to cool the space.
Jul 07, 2017 | Goodman Heating & Cooling
High Electrical bill - Appears to be heatpump problem.
Sound like there are running on emergency heat which is elrctric.Have the system checked out buy a local heating and cooling company. Have they checked the filter and changed them.
Jan 14, 2009 | Honeywell Electronic Programmable...
Goodman Draft Induction Fan Keeps Cycling On and Off
can you write down where the low voltage t stat wire go and disconnect the white wire at the unit to eliminate a short between the white wire and the red wire usually the colors are as follows red is 24volt , green is fan , white is heat, yellow is cooling I want to narrow down the red is not shorting to the white briefly let me know if this is possible if not we can try other checks
Jan 06, 2009 | Heating & Cooling
Furnace clicks many times before igniting
sounds like it could use a new spark ignitor with new pilot assy. will probably die completely soon
Nov 26, 2008 | Goodman Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
186 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
