Question about Frigidaire FRS26R4A Side by Side Refrigerator
How do you remove the water drip tray
Thank you for your instruction, but I needed to know in which direction you pull the tray in order to replace the water actuator
  • 447 Answers
Straight towards you
Posted on Nov 25, 2007
Miele CVA 2660 coffee Maker. Was getting Empty Drip Tray errors. Drip tray contact springs are corroded & broken, no longer reading. The numbers are 06579921 & 06603101. Cannot find parts, help!
Well if you know the part numbers you can try buying them directly from an authorized repair station . Some will not sell you the part because they want to do it for you and soak you at the same time.
If you have the part numbers you can try locating them on ebay or google for them and/or equivalents.
Mar 12, 2016 | Miele Coffee Makers & Espresso Machines
Cva 4070 drip tray issue
Miele CVA 4066 -Empty drip tray warning would not go off even after draining the drip tray, cleaning contacts, and resetting power. Water was coming out from under the empty tray.
I pulled unit out and removed sheet metal in rear around water inlet. when I attached water line and power cord & turned on power, I could see water dripping out of one of the 2 solonoids on the water inlet valve. $168.00 from Miele and no expensive service call.
May 27, 2012 | Miele CVA4070 Coffee Maker
Need to replace water drip tray
Soak it with coke a cola over nite
Jan 28, 2012 | GE Refrigerators
Drip tray is overflowing water onto floor.
Hi Mickey, You have a bad water valve. Turn the water off to your unit and turn off the ice maker. Replace your inlet valve.
May 22, 2010 | Whirlpool ED2FHEXN Side by Side...
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Dec 29, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Water goes directly to drip tray instead of to the brewing head.
Have the same issue with mine. Descaled it all and wouldn't even brew with no coffee OR filter in the housing, so I took it in to get it checked out. Turns out it's the solenoid valve that needs replacing. ~$60 part plus $90 labor, so I've decided to try and find that part and DIY, if I can. I'll let you know how that turns out!
Aug 04, 2009 | Krups XP4030 Espresso Machine
Descaling?
With the selector buttons find Descaling and press OK
This process takes about 35 minutes
1. Empty the water tank, drip tray and grounds container.
2. Insert tray and grounds container, refill tank with with 0.5 Lt. of water and add descaling agent (not the pill or powder used for clean cycle) to tank. Make sure its completely dissolved.
3. Place a container or cup under the steam wand large enough to hold 0.5 lt.
Display says Descaling and press OK
4. Press the water button
Display says Descaling in Progress
after the descaling agent is exhausted
Display says Empty Drip Tray and Spent Grounds
5 Also remove rinse and refill the water tank to Max line
6. Press the water button again
after the machine stops
7. Empty the drip tray and spent. ground container and replace
Display says Rinse Press OK
Display says Appliance Ready
In essence go to Descaling Press OK and follow the directions as they are displayed.
Sep 07, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Descale
Aug 02, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Replacing water actuator on side By Side frigidaire
trying to bring temp down on the fridge side.first i tryed to just turn the temp up. Waited over night no change. Went back to factory setting,still no change. Fridge still under waranty all ready has a new copressor and invaporator installed by fridgaire. The fridge is only a 03 alittle young to have these problems.
Nov 24, 2007 | Frigidaire FRS26R4A Side by Side...
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Frigidaire FRS26R4A Side by Side Refrigerator Logo
295 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
