I front load washer will not turn on. The dryer works and is plugged in the same outlet. We did laundry last night and it didn't show any signs of a problem... it's not the breaker, what else could it be?
IS there a control lock feature on this washer? Push the button and hold for 6 sec if it does. If it doent have this feature then forget what i just typed. Are there any LED lights on at all? DOes anything light up when you push the power on button.? If you know you have power at the outlet, i would assume its your control board. Slide the top panel off and if your handy with a volt meter you will have to do this check im about to tell you in order to determine if your board is bad. you need to follow where the cord comes into the washer and follow this wires to the control boar. If your getting 120Volts to the board, then its probably a bad board. Always becarfull when working on live voltage. hopefully this helps
The latch on the door/lid
