I need to know if the center pin is positive or negative on the power plug on the back of the pavilion f1503 LCD monitor.
  • Alun Cox May 11, 2010
    If you knew what you were doing you would not need to ask this question which leaves one question for you to answer :- Why?
    President:
  • 3,085 Answers
It is POSITIVE
Posted on Jul 31, 2009
    New Friend:
  • 63 Answers
I assume that you need a new power supply (PS). The old power supply should have an indicator on it depicting the pin-out. If it doesn't, you can break open the old PS and look for the capacitor. One end will be market +++ and the other pin will be marked ---. Trace the wire of use a conductivity meter to determine which wire is + and which is -.
Most of the time (but not always), the center is + and the outside is -.
I need to know the polarity of the barrell plug on hp pavilion f1703 that was given to me with out the powersupply. **** w. Pierce dickwpierce@juno.com
It's center pin positive, sleeve negative. Replacement supplies are commonly available online. 12 volts DC, 4 or 5 amps is what the replacements are rated.
Feb 18, 2011 | HP Pavilion F1703 17" LCD Monitor
I need an internal pin out diagram for a 4 Pin connector to connect power supply to a hp pavillion f70 monitor. I do have a power supply with same specs but it has a normal plug with outer as +ve and Inner...
12 VDC , 4.16 A (4,16 A) Frequency: 50/60 Hz Power Consumption: less than 36 W in operating mode.
I think the other two pins are not used. It just requires the 12 Volts DC. +ve and -ve, positive and negative, respectively.
Feb 10, 2011 | HP Pavilion F70 17" Flat Panel LCD Monitor
Find out the power cable
here goes a link to the power cord
http://www.pdaaccessories.net/productDetail.asp?accid=935&searchcat=Laptop+Chargers
Feb 11, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
I need to know the polarity of my Hp Pavilion F1703 monitor as I have just brought a new power adaptor and before I connect up to the mains it says make sure you insert the adaptor the correct way round...
If the monitor does not have a symbol (similar to the letter 'C' with a dot in the middle), the cheapest digital multimeter can be used on the 'diode' or 'continuity' setting to check the input.
If the meter reads between 600 and 900, you are measuring the forward voltage drop of a protective diode.  Any other reading will mean that the positive probe of the meter is on the positive part of the connector.     i.e. If you are placing the positive meter lead on the center pin and the negative on the shell and it reads 600-900, then the power supply needs to have the negative applied to the center pin and the positive on the shell. If the negative lead is held on the center pin and the positive on the shell and the reading is 600-900 then the center pin is the positive input and the shell the negative.
The readings shown above mean that you are measuring the forward voltage drop of a diode meant to protect the unit against improper polarization and it will probably either die or ruin the adaptor if misapplying the polarity.
You can buy such a meter at electronics or auto parts stores for under $20 US.
Jan 11, 2009 | HP Pavilion F1703 17" LCD Monitor
Where do you plug in the power?????
It is powered with a 12v DC adapter:
The small round hole with the pin in the middle..
Hope this helps
Happy New Year!
Chris (ziraffa)
Dec 31, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Ref:hp pavilion f 1503 power supply
HP / COMPAQ
PAVILION 1503 D5061-A F1044A F1044B F1503 1703 F1703 VF51 VF52 L1800 0950-3415 ADPC12416BB ADPC12350BB
Input: 110-240V 50/60Hz Auto-Detect International Compatible Output: 12V DC, up to 5A / 60W max (Great upgarde for lower wattage)
Connector: Barrel, Center +
Dec 14, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Jul 06, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
