Question about Bosch SHU9915UC Dishwasher
Drain was clogged and the dishwasher overflowed. It's a 10yr old Bosch dishwasher. Now water won't flow into the dishwasher but it runs through the cycle and dishes arent clean.
Probably the aquastop (if you have one). We have a similar problem after our owerflow. The dishwasher is starting and running through the programs but no water is coming.
Posted on Aug 01, 2009
Will not drain in drain cycle
If you can hear the pump attempting to pump the water out, disconnect the dishwasher drain hose and place a bucket underneath it and run the drain cycle again. This should clear any clogs along the drain line and prove that your pump works. While you've got it disconnected, remove the air gap vent and clean it. A small, but large enough amout of debris can be blocking the flow of water from the dishwasher's drain hose to the garbage disposal or drain pipe. The air vent has a small cap at the top that can be removed to make cleaning easier by simply flushing it with water.
Mar 20, 2010 | Bosch SHU9915UC Dishwasher
2in.of water standing in bottom when finished
Most likely a clog, either along the drain hose, or more likely, actually in the air gap vent. Disconnect the drain hose from the dishwasher and place a bucket under it. Run the drain cycle. This should clear any clog along the drain line. Remove the air gap vent from the top of the sink and disconnect the other hose. Remove the small cap at the top of the vent by pressing the small clips on opposite sides of each other and lift the cap out. Using either a strong flow of water, or, a thin, long-blade screwdriver, remove any debris from the two hose connectors. (Problem is most likely in the smaller hose connector which is preventing water from flowing over to the other connector to drain out). So, during operation, water goes up the small drain hose, but can't go any further and water remains in the dishwasher.
Clearing the air vent cap/filter should solve your problem.
Mar 20, 2010 | Bosch Evolution 500 SHE55M06UC 24 in...
Water does not get pumped out of dishwasher
I have had this problem a few times. For me all I had to do was unscrew the vent/overshow knob on the sink and clean out the vent. Because the vent is clogged, it does not allow the water to flow out. Clean out the debri and screw the vent cap back on- should work fine.
Aug 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Erestanding Equator PLS600 Overflows
May be this time the drain hose has been clogged or the drain hose is at a higher level than the unit or may be the drain pump has stopped functioning.
Mar 09, 2009 | Equator 20 in. PLS600 Free-Standing...
My bosch shu5315 cycles fine but when finished water is not draining completely. checked screen-cleaned-and problem still exists. Is it the heater? If so how hard to replace?.Note: remaining water fills...
check your airgap by the faucet of your sink. usually a metal cylinder is the cap. then you might have tabs to press in, or the top of the airgap can unscrew. usually i find stuff in there. mostly fishbones.. otherwise make sure the holes towards the bottem left of your dishwasher tub under your filters arnt clogged up. sometimes calcium gets in there a clogs those holes to the drain pump.
if no airgap then check that hole to the disposer. reach your finger in there towards where the dishwasher drain line is coming in and make sure that isnt clogged up.
Feb 24, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Nov 26, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Water won't fill
when facing the dw pull it out from under counter and on the left side there is a panel held on with 2 screws. take that off and under there are the float switches for the overflow. those switches is what causes the pump to run all the time but do nothing else.
Oct 30, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU9915UC Dishwasher Logo
688 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
