LG washer does not spin. Then says
LG washer does not spin. Then says ''E'' for error.
    Brigadier General:
  • 4,090 Answers
This could be several things and cannot succesfully be diagnosed without intervention and testing. Call a service tech to look at it. It could be a blet broken, diesengaed or even a slenoid switch
Posted on Jul 31, 2009
Why on an LG Front loader does the FE code come on and not on Rinse & Spin?
Here is the LG site for washing machine error codes, you can scroll down and find the FE code there:
http://www.lg.com/us/support/product-help/CT10000010-20150140270078-other-error-codes
The site shows the following:
The FE error code indicates the washer is overfilling. This is usually the result of a faulty water valve.
1. Close both water taps.
2. In order to drain out any trapped water, power the washer back on and press the Spin Speed button until No Spin is selected and press the Start/Pause button.
3. Once the washer has drained, restart the wash cycle.
Jan 26, 2017 | LG Washing Machines
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
Ok my LG front loading washer agitates but when it comes to spin it makes a very irritating high grinding noise and does not spin. There is no error displayed but that may be because I stop it before it...
I have a similar problem. The washer was showing error code UE, but would tumble when empty in test mode, but would not spin and made a grinding noise. The bolt that attaches the rotor to the motor was loose and the rotor was spinning on the spindle that rotates the drum. I tightened the bolt, and it spins when empty, but still gives a UE error code when full. Remove the rear cover and check the tightness of the center bolt.
Dec 16, 2010 | LG WM-2277HW Front Load Washer
1 1/2 year old lg WM2496H showed oe error code while washing a heavy unbalanced load. I removed the wet blanket (sitting in water) and tried drain/spin command with empty washer but washer will not go into...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!
Jun 09, 2010 | LG WM2496H Front Load
LG- WM2355C Wont lock and start spinning. Shows
Unplug the washer for fifteen minutes and if that doesn't it is your lock mechanism. You will need a repair man or if you are handy you can do it.
Dec 07, 2009 | LG WM-2277HW Front Load Washer
Error Message and Tub not spinning
UE is likely an unbalanced load or load is too large. Reduce the size of the load and your issue should be resolved.
Jul 21, 2009 | LG WM-2277HW Front Load Washer
Willnot spin, error code 6e
lg wf-t851 will not spin. displays 6e error code
May 23, 2009 | LG WM-2277HW Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
