Question about Kodak EasyShare DX4530 Digital Camera
I have a kodak es530 just installed new memory card
Says it needs formatting pressed continue an hour glass pops up and nothing happens
    Brigadier General:
  • 4,090 Answers
Change the card or try formatting it through a cardreader on your pc
Posted on Aug 01, 2009
Memory card will not format
If other memory cards take the format then your card is fubar.
Aug 25, 2017 | Kodak EasyShare M863 Digital Camera
Difficulty formatting new memory card for a Kodak Easy Share DX7440
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
Dec 01, 2011 | Kodak EasyShare DX7440 Digital Camera
Memory card will not format in Kodak Z760
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    Kodak Easy Share z740 won't format Kodak Memory
    1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
    2. Turn on the camera.
    3. Press the Menu button, then go to the Setup Menu.
    4. Scroll up or down to the Format option, then press the OK button.
    5. Follow the prompts to format the memory card.
    Retrieved from www.kodak.com.
    Mar 29, 2010 | Cameras
    I have a Kodak easyshare LS443 and when I put in a new picture memory card (bought two of them already), after it says 'format memory card' and I do, it just keeps saying 'reading memory card' and nothing...
    Make sure that the memory card you used is compatible w/ your camera. If same issue persists after using the compatible card, camera is unable to detect the memory card. Card compartment is defective. call 1.800.235.6325 for repair.
    Thanks.
    Neerak21
    Sep 25, 2009 | Kodak EasyShare C875 Digital Camera
    Ive purched a new kodak memory card and need to format appears
    Press the menu button, go to setup, go to storage, select memory card, select format. You're done.
    Sep 02, 2009 | Kodak EasyShare DX4530 Digital Camera
    Was OK, but now memory card requires formatting? Kodak Easy Share C-530. I tried several times to put in new memory card, but it always says it needs reformatting and when i try "continue" it then goes to:...
    She is not arguing with the camera. Sheesh. When she says she hits "continue" she is talking about continue for the camera to format the card. But instead of formating the card it says filesystem error e00100. The camera will NOT format the card. I have the same problem. I can format the card on the computer, but again the camera says it can not read the card and needs to format. You choose to format, and it says filesystem error e00100. My card is brand new. So I used cards I have owned for while and used in other cameras. Same thing happens. I tried 4 different cards. A 4gb SDHC, thought that format was not compatible so switched to a regular SD 2gb. Same thing happened. Also tried Standard SD 16mb & 128 mb. All do the same thing.
    Jul 21, 2009 | Kodak EasyShare C315 Digital Camera
    When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
    Use a computer with memory card reader, and read the card using a computer.
    If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
    If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
    If you need to use the camera tonight, then buy a spare memory card.
    If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
    Regards
    Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Kodak EasyShare DX4530 Digital Camera Logo
    99 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
