My miele washing machine fills on all cycles but the prewash
My miele washing machine fills on all cycles but the pre wash. When this happened before, the repairman found a loose connection, and in 2 seconds we were up and running. Can I get to the electronics so I can do this myself?
    Brigadier General:
  • 4,090 Answers
Not adviseable! Work by a serviceperson is also guaranteed and they know the safety rules of entering the electronic region of any appliance.
How much is your life or the life of menbers of your family if you do it incorrectly and some one gets electrocuted?
Posted on Aug 01, 2009
New Miele g6927 sci XML installed today. Error message "open stopcock". This is open and is filling with water. However machine not progressing to wash. Is there a way to reset
the program will not progress to wash until the set water level is reached
at that point the water in is stopped and the wash cycle begins
If that is not happening get in the service technicians for a warranty fix
Feb 11, 2018 | Miele Washing Machines
If I use the pre wash cycle do I need to add detergent for this cycle and then again for the regular wash cycle/
Depends on the machine but in most cases, yes a prewash requires an additional detergent to remove the heavy dirt and grime and then when it is done soaking, the regular cycle kicks in and runs
Oct 29, 2017 | Washing Machines
What is a pre wash? which detergent to be used in the pre wash compartment?
A prewash is exactly that a wash that takes plaxce before the main wash cycle for heavily soiled clothes, you can use the same detergent as you do for main wash. I do not think that I have ever used prewash.Hope this helps
Jan 06, 2016 | Kenmore Elite 45986 Front Load Washer
I have miele w500 problem is the soak/pre-wash
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Nov 14, 2012 | Miele Novotronic Premier 500 Front Load...
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Indesit Dishwasher DI67.Cycle phase lights(prewash and wash)flash
I,d suggest Paying The $19.99 fee, on this site to get premium assistance. You,ll have technicians queuing up to solve your problem. And You,ll Have Solutions Within An Hour.
****** Please Do Not Rate This******
This Suggestion Is Information Only.
Good-Luck Mike @ Compurepair.
Feb 28, 2008 | Indesit 24 in. DI67 Free-standing...
Pre wash not happening
poss blocked filter which also controls your pressure system, on your machine I believe if the prewash ligbt is flashing it would indicate a blockage there
Jun 13, 2007 | Hotpoint WMA46 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
