Question about Saws
Pump doesn't work on tile saw I just bought. It's a dry saw rather than a wet saw. Also no user guide was included with the saw. Is this nornal and if so , how do I get one.
    Brigadier General:
  • 4,090 Answers
What brand of saw? Ideally you should return it for a refund or replkacement. It sound like it might have been a demo saw and was sold cheap. But if it doesn't work and you have proff of purchase take it back. If it is a GE model I have a manual i can type up for you. I am in australia where is your location?
contact me on admin@nettiser.com.au if you need to
Posted on Aug 01, 2009
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
Can I laquer over pebble tile that has been sealed?
Check with the "dry treat" manufacturer for their recomendation.
Be very careful if the pebble tile are the floor of a shower.
If you wet the pebbles and they get a wet look you should be OK.
If they stay looking dry the wet look sealer may not stick.
Some roughing up with sand paper may do the trick.
Aug 27, 2013 | Saws
TILE SAW WON'T SPRAY, PUMP AN MOTOR RUN CHECK FOR DEBRI HOW DO I CLEAN TUBING TO SPRAYER I THINK IT IS CLOGGED
Make sure pump is submerged i water
Remove tubing from pump discharge and see if pump is pumping water/ If so your tubing is clogged between pump and saw. Remove tubing and rinse out with hose.
Nov 28, 2012 | Ryobi Saw. 3/4 HP 7 in. Wet Tile Saw WS721
Was cutting tile and it just shut off. Blade seemed dull. Does blade stop running when it needs to be replaced?
no it does not there is a fault with the cutter arm in most cases its a broken switch or its brusges are too worn
let me know if you need more advice
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Ryobi WS720S wet tile saw. Will not spray
Check the pump operation and pump intake screen for plugging. Make sure the water reservoir is not full of cutting debris.
Jan 24, 2010 | Saws
Applied dark brown glass tiles and those that were cut with a wet diamand blade saw are darker in colour to the others. will cut tiles become the same colour as other non cut tiles?
THIS COULD BE CAUSED BY 1 OF TWO THINGS, WHEN YOU USE WATER TO CUT ANY TILE YOU ARE INTRODUCING WATER TO THE INSIDE OF THE TILE WHICH WILL CAUSE THIS DARKENING OF THE TILE, 2ND WHEN YOU WET CUT USE A SLOW LITE PRESSURE LET THE BIT DO THE WORK TO MUCH PRESSURE AND NOT ENOUGH WATER WILL CAUSE OVER HEATING AND DARKEN THE TILE. HOPE THIS HELPS. ALSO
THIS DOESN'T ALWAYS WORK BUT AFTER CUTTING PLACE TILE IN A HEATED AREA TO DRY OUT THE WATER ,THE GLAZING IS WHAT PROTECTS THE INSIDE
Dec 01, 2009 | RTO 1/8"wet Diamond Glass, Tile, Stone,...
Where can I buy a tile guide
hi,
this site will help you to buy
http://www.ceramic-tile-floor.info/
thank you
Sep 22, 2009 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
How to fix a tile saw pump
take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Jul 14, 2009 | RTO 6391K Felker 24" Tile Master Plus Wet...
Tile Saws for shor and vurved cuts
A 100mm angle grinder is used for that kind of work. It can also be used for "L" shaped cuts and for making holes. It is usually being used dry and more rarely used wet
Aug 27, 2008 | Black & Decker WP900 6 Inch Random Orbit...
Saws Logo
155 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
