Samsung SP42W4HPX, black semi circle bottom of screen & 3D effect
I have a samsung SP42W4HPX, the screen has a black semi circle at the bottom and the picture has a 3D effect and the colour is wrong. Anyone know how to fix this please???? Thanks
  • 34 Answers
Sir/mam the problem of your t.v is weak picture tube,i have encountered for that kind of problem already.
Posted on Aug 01, 2009
SOURCE:
How to fix Vertical bar on Samsung Electronics 55 UN55ES7100F?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 16, 2016 | Samsung Electronics Samsung 55" UN55ES7100...
Good day again my Samsung 55''un55es7500 led 3d tv has tin g oldish lines from top to bottom of left side of tv screen can you assist in fixing problem
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 17, 2015 | Samsung UN55ES7500 55 Inch 3D 1080p Smart...
Large Black Pixellated circle on SL600 camera
LCD screen is damaged - repair probably very expensive.
May 26, 2017 | Samsung SL600 Digital Camera
3d Samsung plasma craked screen & won't turn on ,can it b fixed
you will have the replace the entire plasma screen. This will NOT be cost effective, will be cheaper to buy a new set vs. buying a replacement panel. Toss the set on Ebay or your local craigslist as a parts unit. If you get $60-80 for it, take the money and run !!!
Sep 07, 2012 | Samsung 55 LN55C750 3D TV
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Nov 09, 2009 | Samsung HPN5039 50 in. Plasma HDTV
Blue circles on images forehead, cheeks and chin.
Try cleaning the contacts on the connectors going into and out of the Tcon board, if that doesn't fix it replace the board, here is the manual if that helps.
Samsung HL S4266W Owner Instructions Manual
Jan 06, 2018 | Televison & Video
Fitting instuctions for replacing lcd screen on my samsung e250 mobile phone
ok...
1.take off battery cover, remove battery, memory card and sim card
2. remove the five screws on the back... two at the bottom, two in the middle and one on the mid top right and take off this cover, remember! keep the screws safe
3. slide the phone up and take out the two screws on the left and right paralel with the battery tabs then remove the two screws ether side of the camera...they might be covered by rubber coverings, these pop out easily
4.now you can prise the top of the screen off with a small flat headed screwdriver
THERE ARE TWO OPTIONS HERE, IF THE REPLACEMENT SCREEN HAS NO RIBBON CABBLE ATTACHED THEN FOLLOW FROM FIVE, IF IT HAS ONE CONNECTED THEN FOLLOW FROM
5. its conected to a ribbon cable, remove the tape and slide out the cabble from the screen.
6. now take out the screen PCB from the plastic casing and replace it with your new one and put the ribbon cable in and clip it back together, now reverse stages 3 to 1 to put it back together.
7. if the ribbon cable is attached now you must look at the PCB board on the back for a square copper line, on the left of this there is a big black square just smaller than the copper square, prise this off with your finger nails, keeping it to the side take the PCB up about 2mm and then fold the bottom of it to revele it is conected to a ribbon cable by a bigger version of the black square so prise this off and take the PCB and put it safely to one side.
8. look on the front of the phone under the top bit of the screen, there should be a semi circle in the plastic with a black circle in the top of it, use your nail or a flat headed screwdriver to pop it to the other side of the semi circle, now the slider should go past what it used to o you can slide it up to when you can see the ribbon cable go down through the phone, now push the black square end through and you should be able to slide the whole front off.
9. replace the screen by taking the screen PCB out and repacing it, then thread the ribbon cable back through and slide the front on while making sure the back circle goes into the semi circle and to the top side of it, then thread the black square through the phone to the front and clip the phone front back on.
10. snap the black square back on to the back Circuit then put the circuit back into the phone and snap the small black square back on then go from stages 3 to 1 to put it back together.
this should be fairly easy to do for most people.
Jul 03, 2008 | Cell Phones
3d picture
multicolored 3d effect is a problem with what is known as convegence... ussally there are two large chips (ic) that blow. gennerally they have to be replaced mabe some fuses and resistors..
May 02, 2008 | Samsung HCL4715W 47" Rear Projection...
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
191 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
