Question about Dryers
Our dryer just stopped in the middle of a load and won't start up again at all
    President:
  • 1,776 Answers
I would check for a burned thermal fuse. The thermal fuse is located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. It can be checked with a multimeter or ohm meter for continuity. If it has no continuity, it is bad and will have to be replaced. Hope this helped and best wishes.
Posted on Aug 01, 2009
  • Bruce Canfield
    Bruce Canfield Aug 01, 2009
    Sorry. First make sure that the house breaker for the circuit the dryer is on is not tripped, before you tear into the machine to check the thermal fuse.
We have an old Frigidaire dryer (1993). It stopped in the middle of a drying and won't start again. The light goes on, the buzzer goes off when tested, but it won't start turning. It is too...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Dryers
Dryer appears to 'overheat'...starts a load but stops before finishing then won't start again for hours...
Test air flow. Remove the exhaust hose at the rear of the dryer, run the dryer and form an opinion on the volume of air flow, hook the hose back up, turn on dryer again and verify that the same volume of air exits the building. Usually a build up is the cause of your complaint.
May 13, 2011 | Kenmore Dryers
IN THE MIDDLE OF DRYING A LOAD IT STOPPED AND NOW WILL NOT START AGAIN
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 31, 2010 | Whirlpool Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Intermintent working
How old is this dryer and does it get slower on heavy loads? Or do you hear a hum when loaded ?
Sep 28, 2008 | Whirlpool LER7646E Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Kenmore dryer stopped working, start button does nothing
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
Top Dryers Experts
