Question about Cameras
Canon sd450, e18, need schematic of lens
Hello, I have a canon poweshot sd450 with a e18 eror. I have been search then internet for a schematic or picture showing the lens and can't find one. Any suggestion where to look?
    Brigadier General:
  • 4,090 Answers
Http://www.e18error.com/
here are instyructions and a reference to the schematic at the bottom of the page.
cheers
Posted on Aug 01, 2009
E18 error on powershot canon
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Sep 27, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
E18
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 22, 2009 | Canon IXUS V2 Digital Camera
E18 appears on the camera and the lens won't close
Mar 27, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 10, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
How disassemble?
Open battery covering and (A/V/USB) covering - find a hidden screws there.
Aug 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
E 18 problem
Hello there,
Jun 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Dropped my camera canon sd450
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 17, 2008 | Canon IXUS V2 Digital Camera
E 18 problem
The dreaded E18 error happens to many Canon cameras.
This error occurs when the lens is mechanically stuck. Sometimes you need it to be serviced and most times you can fix it, but even then it's a good idea to have it serviced soon. The cause to this may be dust, dropping and other mechanical problems.
1. Check if the battery is full
2. Check for visible mechanical problems (obstacles, debris). You may notice the lens is not exactly straight - in this case this is the cause of the problem.
3. Turn the camera off.
4. This needs to be done with gentle force: Take the camera in one hand and with the other gently take each part of the lens and gently move it round in a circular movement. Do this with both sections of the lens. You will hear a little "click" as it pops back in place.
5. Power the camera on.
Hope this helps!
Jan 09, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
Canon SD 450 E18 error
see posting http://www.fixya.com/support/t102982-e_18_problem
Sep 08, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Cameras Logo
142 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
