Question about Sentry Fireproof Safe
The dial on my safe is not turning smoothly. It will start out ok, but about half way through the rotation, it almost seems like its binding up and gets real hard to turn for about a third to a half turn, then this repeats. Any ideas what this might be?
    Brigadier General:
  • 4,090 Answers
Someone tried to break in and damaged the tumblers It sounds like the tumblers are out of the ball race. Other than calling in a sagfe expert it cannot be solved by guesswork
Posted on Aug 01, 2009
My Sentry 3150 safe is closed and locked and the lock/dial is stuck. The dial only turns between 20 and 25.
If their "Frequently Asked Questions" do not address this problem, I would probably call them and ask for clues... https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us
Here's what one guy did to open a Sentry safe.
Jun 15, 2014 | Sentry Fireproof Safe
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Noise from right front tire
jack up front left on level ground ,support and chock rear wheels and set park brake ---look and check the cv axle for leaks,tears or damage -put in neutral and watch axle should turn smoothly turn steering wheel to left and rotate tire again watching axle if their is binding or grinding or studder movement than axle is damaged and needs to be replaced
Apr 08, 2014 | 2005 Ford Freestar
Engine rotation is up 1.2 aceleration. speed is only 30 km/hr
Either your brakes are binding or the transmission is slipping. Find a safe smooth surface with a slight incline and place the transmission in neutral. Release the brake and the vehicle should roll with minimal effort. If preferred, the same checks can be performed simply by safely supporting the vehicle and verifying that all the wheels roll freely with the transmission in neutral and brakes released. Transmission problems will often be accompanied by leaking fluid or burnt smell on the dipstick. Dark red fluid is an indication of burnt fluid or neglected maintenance.
May 04, 2011 | Toyota Passenger Cars & Trucks
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
20 seconds. The red indicator light will go off and any previous
light will start flashing.
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
light will go off.
Rotate the time dial clockwise to the first desired ON time.
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
What is the torque spec. for steering head, and what is the cause of loosening
Bearings break in and wear down over time. A good mechanic will adjust the steering stem bearings during the 600 mile check up. Make sure the bearings have grease. Snug up the nut so it is firm and reasonably tight (you do not want the bearings to bind) . If the steering is starting to bind back off till it turns smoothly. Hint : It is easier to feel firmness or binding if the wheel is off the ground when turning the bars.When there is a fine thread nut involved I do not think it is safe to use a torque wrench. Hand snugging can be enough to bind the system. Double check the feel after you put the wheel back down , you may have to tighten just a touch.
Oct 08, 2010 | 2005 Yamaha Road Star Midnight Silverado
Hello I lost my instructions for theej351c, can you help?
1. Move control lever to OFF-CLEAR for at least 5 seconds; red indicator light will go
off, and all previous time settings will be cleared from memory. (If timer fails to set, leave in off
position for 15 minutes.)
2. Move lever to ON. RED INDICATOR will start FLASHING.
3. Check a clock; then rotate time dial clockwise at least one click, stopping at the half
hour nearest to present time. NOTE: When rotating time dial, do NOT accidentally PRESS at
the same time. (While rotating dial, keep pressure, pulling out on the dial to avoid accidentally
setting an incorrect time.)
4. Press pushbutton once to enter present time. RED INDICATOR will go OFF, present
time has now been recorded.
5. Rotate time dial clockwise to desired ON time; RED light will PULSE momentarily
with each click.
6. Press pushbutton to enter ON time; controlled light(s) will turn on.
7. Rotate dial to desired OFF time.
8. Press pushbutton to enter OFF time; controlled light(s) will now be off.
9. Repeat Steps 5-8 for each addition ON/OFF period.
10. Continue to rotate time dial for at least 24 hours from the first ON time to complete
this program, at which time the RED INDICATOR light will come ON and stay ON,
indicating timer is in AUTOMATIC mode. NOTE: Dial does not rotate automatically
after setting to indicate time of day.
Oct 26, 2009 | Intermatic Programmable 24 Wall Switch...
I know the numbers but I don't know how many times to turn it and in what order
start at 0 counterclockwise pass the first number 3 times and stop on it the fourth. clockwise pass the next number 2 times and stop on the third, counterclockwise pass the final number once and then land on it. Finally turn the dial clockwise until the dial locks into place. In some sentry safes you do the same thing except you need to reverse the rotation.
Oct 01, 2009 | Sentry Fireproof Safe
Programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Sentry Fireproof Safe Logo
155 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
